Old 06-24-2020, 09:14 AM   #1
Hillsboro , Oregon
Has anyone painted their AC shroud?
I'm wondering what it would be like if I painted my air conditioner shroud gray or silver. Has anyone done it? It seems like it would blend in better on my 64 Streamline.
Warden Brown is offline   Reply With Quote
Old 06-24-2020, 10:08 AM   #2
1969 18' Caravel
Greenville , whereEverIroam
Images: 20
Sure, you can paint it. I believe in the 1960s airstream painted the shrouds silver
Just be aware that, like vinyl or aluminum siding, once you paint it, You will have to keep repainting it every few years as the sun beating down on it will eventually cause it to crack and peel over time.
skyguyscott is offline   Reply With Quote
Old 06-24-2020, 10:12 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
You could try it, really depends on what the original is made out of.
I tried it on an IconDirect replacement, no go.
"HDPE sheet is produced with a closed cell structure polymer. This means it will not absorb liquids, but also means that paint or stain will not adhere to it. The best way to obtain a colored sheet is to have it produced that way!"
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Worry...a brain exercise done when it really wants to sleep"
RLC
Tahawus
Old 06-24-2020, 10:49 AM   #4
Hillsboro , Oregon
I'm looking at purchasing and painting a Dometic Penguin II. I'd love to see a picture of any trailer with a painted shroud, if anyone has one to share.
Old 06-24-2020, 11:14 AM   #5
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Painted AC
See attached photo. This was done with automotive paint. Rattle can attempt was a failure.
BambiTex is offline   Reply With Quote
Old 06-25-2020, 09:55 AM   #6
1976 31' Excella 500
Pahrump , Nevada
Painted shroud
l am doing a total restoration on myb76 excella l took my shrouds from my mach 8's to a sheetmetal shop and had them make mirror plate stainless covers. l the desert sun the plastic only lasts a couple years. These babies only cost 300 a piece to be made for a lifetime of use no painting, no replacing from breakage.
tnew52654 is offline   Reply With Quote
Old 06-25-2020, 10:08 AM   #7
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
I just painted my coleman mach 2 weeks ago ...i used plastic rated spray which ive used on other plastic parts before and it works good.
You may have to redo in a few years but its all of 20min work !
It looks way better than the white white one. I did wait until was out of warranty just in case there was an issue.
rucos is offline   Reply With Quote
Old 06-25-2020, 10:10 AM   #8
Silver Star
rucos's Avatar
1970 23' Safari
Im looking at doing an aluminum shroud as well
...love the stainless one!!
Old 06-25-2020, 11:28 AM   #9
Crewe , Virginia
Those babies sure are nice too! They haven't even fallen off being upside down like that either!
Dspchef is offline   Reply With Quote
Old 06-25-2020, 12:50 PM   #10
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Can we back it up one step?
How do you remove the shroud? (videos preferred)
cazual6 is offline   Reply With Quote
Old 06-25-2020, 01:07 PM   #11
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Rattle Can Will Do It
I painted the white plastic shroud on my Domestic Duo-Therm some five years ago with the Rust-Oleum product shown below.
You must clean the surface completely using TSP (or similar) and then use denatured alcohol as the final cleaning fluid to ensure the paint adheres properly. Once coated (it may take 3-4 light coats for uniform coverage) add a couple of additional layers of clear coat to lock in the metallic look. Clear coat is easily touched up in a few years to maintain the appearance.
Name:	Screen Shot 2020-06-25 at 2.58.27 PM.png
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 06-25-2020, 01:20 PM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Both my Penguin and Brisk Air have 4 screws just above the roof line, two in front and one on each side. Once these screws are removed the shroud lifts straight up.
Be careful, the start capacitor stores energy similar to a battery, but higher voltage.
Alan
Old 06-25-2020, 01:27 PM   #13
1986 31' Sovereign
Miami , Florida
On my 1986 Sovereign, I painted the A/C shroud “Gator Blue” with Krylon. Needed to redo it every couple of years. But, I liked it so not really a chore...
new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 06-25-2020, 01:33 PM   #14
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Krylon Fusion is good for plastics.
Colors and metallic finishes are available.
Alan
Old 06-25-2020, 02:16 PM   #15
2002 19' Bambi
Lafayette , California
I painted ours silver years ago and it still looks fine even with California sun. Rattle-can silver and then rattle-can clear coated. I think the clear coat is important. Takes a couple to three cans of silver.
Tim
Tim A. is offline   Reply With Quote
Old 06-25-2020, 03:13 PM   #16
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
Mine is silver on the bottom half and off white on the top half. Got belt molding riveted around the middle that holds blue trim. That's on 86 Colman.
Streamracer is offline   Reply With Quote
Old 06-25-2020, 03:18 PM   #17
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I have painted them in the past. I would let set in the sun for awhile, then wash good, as already mentioned, and use spray paint.
guskmg
Old 06-26-2020, 03:29 PM   #18
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Painting is a good idea, the paint will protect the plastic from ultraviolet deterioration, your plastic will last longer, yes I painted mine silver looks like it was mento be that way.
bibbs is offline   Reply With Quote
Old 06-26-2020, 03:58 PM   #19
r carl's Avatar
Lin , Ne
Makes you wonder why airstream does not paint them instead of leaving them SOB white.
Old 06-26-2020, 04:08 PM   #20
1969 18' Caravel
Images: 20
Simple. It’s added labor cost for Thor with no return on investment. Thor’s MO relies on the owners to do much of the finishing work needed for the trailers anyway.
However, if there was enough aftermarket interest, I’m sure they could offer a stainless steel AC shroud as an upgrade along with the stainless steel water heater covers, stainless steel vent covers, etc.
Has anyone painted their A/C shroud silver or grey 10brink Exterior Restoration Forum 12 08-04-2016 12:16 AM
Has anyone painted this trim? TMT Cabinets, Counter Tops & Furnishings 4 09-09-2015 05:54 AM
Has Anyone Else Had a Bear Climb In Their Airstream? cclarkego Off Topic Forum 117 01-17-2011 08:30 PM
Has anyone ever added on to their airstream wvairstream Full-Timing 18 11-16-2008 09:24 PM
Has anyone ever removed their air conditioning from engine compartment Mr. D Mechanics Corner - Engines, Transmission & More... 19 06-07-2007 07:11 PM
