Old 04-17-2021, 08:47 PM   #1
1972 29' Ambassador
RALEIGH , NC
Got Armstrong AC running but I need thermostat voltage help
I replaced the potential relay and capacitor and have the unit up and running after sitting for 20 years but the thermostat is missing. (I jumpered the wires together instead) Is the 24V AC or DC voltage? The trailer is 300 miles away and of course I assumed that the schematic had that info, any help would be greatly appreciated!
LakeFall is offline   Reply With Quote
Old 04-17-2021, 09:21 PM   #2
2007 22' International CCD
Looking at the schematic, it’s 24 volts AC from that transformer. A Standard thermostat will work fine.
Old 04-18-2021, 04:54 AM   #3
1972 29' Ambassador
RALEIGH , NC
So if a transformer secondary voltage isnt specified then it is the same voltage type as the primary voltage?
Old 04-18-2021, 05:40 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Transformers only output AC voltage. Diodes are required to convert that to DC and your schematic does not show any diodes. 24 volts AC is pretty much standard in the HVAC world.
Tom
Old 04-19-2021, 05:11 PM   #5
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
The original thermostat is a standard mechanical unit. It generates no voltage.
Emerson 1C26-101 Mechanical Heat/Cool Thermostat will do. $10 on Amazon
cbburke is offline   Reply With Quote
Old 04-20-2021, 07:51 AM   #6
TomW's Avatar
1967 26' Overlander
I replaced my original mechanical thermostat with a battery-powered digital version primarily because the digital model is immune to a door being slammed and controls better in general.
Tom
Need thermostat for Armstrong A.C.? Kirti Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-31-2021 05:08 AM
Anyone got a thermostat for an Armstrong AC Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 12 08-05-2013 09:14 PM
HELP, On Armstrong AC Thermostat mburgess1431 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-27-2012 01:07 AM
Armstrong Thermostat Beginner Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-07-2010 07:49 AM
Thermostat Lost 1975 Armstrong Collusion Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2007 05:31 PM
