01-22-2023, 01:35 PM
2020 27' Globetrotter
Saint Johns
Furnace Will Not Ignite
Our furnace has quit working in our 2020 27’ Globetrotter. It’s not the sail switch- we’ve replaced that a year or two ago and we’ve checked the one being used. There’s no debris on it and our electrical meter shows it working exactly as it should. There is a switch reading “off/reset” and we turned it off then back to reset (“reset” is the position the furnace runs in). At first the furnace started up correctly (after purge the furnace ignited and ran properly). Then after we reassembled the covers it once again didn’t work- runs purge but never clears to ignite. So we are thinking the control panel is bad. Has anyone on this group had similar issues and what was your fix? Any and all ideas welcome, thank you for you help!
01-22-2023, 01:43 PM
2017 28' International
Jim Falls
, Wisconsin
This may be a dumb question: Have you tried other gas appliances?
If you have, and I assume so, you may need to take this in to a repair place. Doesn’t have to be an Airstream dealer. In fact a decent furnace repair person probably could get it fixed for you.
01-22-2023, 01:45 PM
Saint Johns
Yes, the other gas appliances work (stove, hot water heater).
01-22-2023, 01:46 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Furnace model number?
01-22-2023, 01:50 PM
Jim Falls
, Wisconsin
Is it getting ignition spark? It seems odd that a 2020 furnace should have that many issues.
I might try to get to the furnace and make sure all the connections are tight (no lose wires).
01-22-2023, 02:40 PM
2021 19' Bambi
Latham
, New York
The flex hose feeding propane to the furnace on my 2022 got kinked.
01-23-2023, 09:36 AM
2019 27' Globetrotter
2023 30' Classic
Denver
, North Carolina
I had similar problems on my 2019 27 GT. I cleaned the sail switch, which did not look dirty and could get the furnace to work but only intermittently. I ended up replacing the control board with a Dinosaur control board, problem fixed.
Dave S
01-23-2023, 08:10 PM
1972 31' Sovereign
Cooper
We had that problem with our '72 Sovereign while camping in New Mexico. After checking electrical connections, propane and thermostat, I finally read the furnace owner's manual where I discovered that our furnace has a safety feature which prevents ignition when there is not enough oxygen to support operation. Simple fixes: add layers of clothing, use electrical heating or relocate to a lower altitude. keepontravlin
01-23-2023, 08:18 PM
2016 27' International
Anacortes
Ours was the control board
The first night on our first of the year roadtrip, we discovered our furnace wasn’t working (and it may not have been working for some time). Looking at the furnace manual, it said to look at the blinking red lights at the control board, and from the lights seen, that gives a clue to the problem.
Fortunately, we were close to a AS dealer, and were still under extended warranty.
They accommodated us and spent a few hours mostly bending, rebending the sail switch in a jig designed for the purpose. Closing time, and they allowed us to spend the night in our trailer with shore power. The next morning, they spent a couple more hours, deciding to try replacing the control board…and the new one has been working ever since (about 4 years later).
01-30-2023, 03:22 PM
Solon
, Iowa
Peter - I have a 2019 Globetrotter 27FB, with an Atwood AFMD25 model furnace. Mine just went out last night and have another post asking the same questions. Did you ever gets yours fixed?
Tom
01-30-2023, 04:56 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
I just fixed my barely used furnace on my 2021, the ignighter was bad.
Symptoms:
The furnace would start and run for 15-20 minutes, then turn off before reaching temp. Once it turned off, it would not re-ignite.
Let me know if this sounds familiar, I can walk you through replacing...its fairly easy.
I have a Dometic DFMD30111, the igniter & board are below, if you have the same model.
Hydro Flame 35100 Electrode for... https://www.amazon.com/dp/B016MWVNY6...p_mob_ap_share
DOMETIC 31501 Dc Furnace Circuit https://www.amazon.com/dp/B01KHLH77K...p_mob_ap_share
- Stewart
01-30-2023, 09:11 PM
2022 28' International
Lexington
, Kentucky
I have a 2023 International. Furnace wouldn't start & had to take it back to the dealer. Sail switch was faulty.
01-31-2023, 07:30 AM
2021 27' Globetrotter
San Francisco
I have had this problem several times, and every time it has been the sail switch. Not fun in the middle of a cold night or in the rain.
Those are very finicky and in my case I was never about dirt, the blade is very close to the fan’s external housing and contact between the blade and the housing can interfere with the switch getting pressed.
I’ve had to kink my sail switch slightly to keep it away from the housing to address this, and it’s worked.
01-31-2023, 07:42 AM
Saint Johns
The model number is AFSD20111.
01-31-2023, 07:43 AM
Saint Johns
Model number
Originally Posted by gcinsc2
furnace model number?
afsd20111
01-31-2023, 07:49 AM
Saint Johns
Tom
I changed the circuit board and the problem remained. But I got a hint I’ve not tried yet- because strangely the furnace is working now. The hint I’ll pass along is a weak ground connection. This might make sense-the ground connection is right in front of the fan and above the circuit board on my model and the ground wire and other circuit board wires are pressed when the hatch is screwed on. This could explain why our furnace would run when the hatch was off- if the ground was loose perhaps then was making connection. We are limping home and I intend to check this connection and all other connections well once settled, but hoping this continues to work these last few days of traveling.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Furnace Fails To Ignite
TravisH |
Furnaces, Heaters, Fireplaces & Air Conditioning |
0 |
08-26-2021 09:06 AM |
LP furnace fan won’t turn on, furnace will not ignite
Marvelous |
16 |
01-20-2021 07:23 PM |
2018 Atwood furnace failing to ignite
cegardner |
12 |
12-08-2020 03:12 PM |
Helpl-Atwood Furnace 8525 won't ignite
LAWBC |
1 |
01-12-2017 12:05 AM |
Both Furnace and Water heater won't ignite?
sound-silver |
Electrical - Systems, Generators, Batteries & Solar |
19 |
11-17-2009 07:30 AM |
