02-07-2020, 03:31 PM
2019 23' Flying Cloud
West Islip
, New York
Furnace questions from newbie
My furnace won’t go on unless I am hooked up to shore power. Propane supply is fine and stove and oven work. Would welcome any thoughts or possible solutions.
Thanks.
02-07-2020, 03:34 PM
2002 30' Classic S/O
Fleming Island
The furnace needs 12 volts. Do your lights work without shore power? Do you have the USE/STORE switch in USE?
Al
02-07-2020, 03:41 PM
West Islip
, New York
Yes and yes.
02-07-2020, 03:55 PM
2002 25' Safari
Dewey
Are you sure it is not trying to start the heat pump? That would require shore power.
Richard
02-07-2020, 04:00 PM
West Islip
, New York
No, it was definitely on furnace mode. But thanks.
02-07-2020, 04:04 PM
1987 25' Sovereign
Fort Collins
Has it worked before this?
Alumacoot
“We are confronted with insurmountable opportunities.”
02-07-2020, 05:34 PM
Fleming Island
Your batteries may be so low that hey can't run the furnace. Can you measure voltage with and without shore power?
Al
02-07-2020, 06:03 PM
2018 25' Flying Cloud
Portland
, Oregon
It does sound battery related. If the voltage drops significantly when you try to run the heater that points to either batteries that are shot or something like corroded battery terminals.
02-07-2020, 06:12 PM
2019 27' International
2014 25' International
Boulder City
, Nevada
Our 2014 International checked out fine at the dealership when we did a walk through connected to power.
At home the batteries were dead and would no longer hold a charge. Replaced them and we lived happily every after.
Our 2006 Safari had AGM sealed batteries and 80 watt Solar. Batteries were fine at purchase and still running fine when we sold it in 2014.
If your dealer came over with a battery pack on a small dolly to demonstrate the interior lighting... Dead on Arrival.
Often the trailers sitting on a Dealer's Lot for months have already killed the batteries. Like the previous posts... if it works on power but not battery... problem solved.
Human Bean
02-08-2020, 06:04 AM
West Islip
, New York
Thank you all. Will check battery voltage.
02-08-2020, 10:01 AM
Rogers
, Arkansas
Did you try to turn on your inverter? Usually located by your water level meter. I know my television doesn't turn on wi thout that on.
02-08-2020, 12:10 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
No. No. No. Inverter has no connection to the furnace. Just the few inverter outlets like tv and dvd and maybe one more random one under the dinette (most models).
02-08-2020, 01:47 PM
Rogers
, Arkansas
Very Good Point
Picked our 2019 AS up in December and the batteries did need to be replaced. Our 2019 has a 6/18 manufactured date. No charge for that long does kill batteries.
Should be a warranty item. It was for us.
02-08-2020, 04:37 PM
2014 27' Flying Cloud
Stowe
, Vermont
The furnace blower needs 120 volts, either thru shore power or generator (inverter powering the blower may work in some models). Call your dealer for details for your specific trailer.
02-08-2020, 04:40 PM
2007 22' International CCD
Corona
Huh? Most Airstream trailer propane heaters run on 12 volts. If the air conditioner has a heat strip or is a heat pump, THAT does need 120 volt shore power or generator.
02-08-2020, 05:19 PM
2017 27' International
Lake Havasu City
What Rich said. Your Flying Cloud's furnace blower does not need 120 VAC. It's a Suburban RV furnace that runs on 12 VDC.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Furnace fumes from new furnace
rosser7 |
LP Gas, Piping, Tanks & Regulators |
15 |
06-01-2013 09:17 AM |
full-time winter living problems, questions by college girl (freezing temps, furnace)
icedcacti |
Winter Living |
30 |
08-24-2010 08:07 AM |
Furnace questions and scary sounds in turns
amathis55 |
Furnaces, Heaters, Fireplaces & Air Conditioning |
2 |
03-07-2006 05:05 PM |
Questions, Questions, Questions
LowellN |
Repairing/Replacing Floor &/or Frame |
5 |
10-28-2004 07:23 PM |
2- Questions -Switches? & Furnace Wires?
05ModPod |
Electrical - Systems, Generators, Batteries & Solar |
28 |
05-12-2004 04:39 PM |
