01-18-2021, 03:41 PM
PLANO
, TX
furnace not ignited
I bought a 1992 29' Excella about one month ago. The furnace was working then. Now it only blows cold air. What do I need to check to fix so that it will blow hot air? I followed the instruction and try turn the manual gas valve on and off few time, no luck. Thanks in advance.
01-18-2021, 03:52 PM
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
Xin Li,
Can you post the make and model of the furnace?
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
01-18-2021, 04:39 PM
1994 34' Excella
Warren
, Manitoba
That looks like a Suburban furnace, and you need to open the combustion side and check the sail switch. Do a search on the internet on "Suburban furnace" and you will see a You tube on how to check the sail switch, and replace if necessary. But first, check to see if you have propane, by lighting the stove. Alkso confirm that the shut off valve below the trailer is open.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
01-18-2021, 05:24 PM
Somewhere
, South Carolina
If CBWELL is correct and that is a Suburban after you get the model number go to https://myrvworks.com/manuals/ select FURNACE then SUBURBAN. Darrell has 13 PDF's for Suburban furnaces. Some are model specific. You might find an applicable manual to assist.
S/OS #001
01-18-2021, 06:11 PM
PLANO
, TX
It is a suburban furnace.
01-18-2021, 06:12 PM
PLANO
, TX
it still have propane.
01-19-2021, 05:37 AM
Somewhere
, South Carolina
With the model number you can review information specific to your model in the link I provided.
When it tries to start do you hear any spark clicking sound?
Do you smell gas while it's trying to start?
Do you have an electrical test meter?
Gas stove burner works?
S/OS #001
01-19-2021, 01:58 PM
PLANO
, TX
fixed. it was the contact to the igniter not properly connected.
01-19-2021, 03:54 PM
1994 34' Excella
Warren
, Manitoba
That was an easy fix! Glad everything worked out.
ACI #7394
1976 22' Argosy
Hensley Hitch
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Replacement Suburban Furnace – Old vent tube assembly does not slide on new furnace.
Harrysheets |
Furnaces, Heaters, Fireplaces & Air Conditioning |
5 |
07-16-2020 10:44 AM |
Dometic heater zone 2 not working on furnace, not hot on HP
sfgirl |
General Repair Forum |
13 |
11-06-2015 02:21 PM |
Furnace fumes from new furnace
rosser7 |
LP Gas, Piping, Tanks & Regulators |
15 |
06-01-2013 10:17 AM |
Suburban furnace works sometimes, not now
Naturescalin |
16 |
01-24-2006 05:37 PM |
Furnace not firinig up....
Guitars |
5 |
01-12-2003 01:39 AM |
