Old 10-01-2020, 06:45 AM   #1
Lthrncktrvlr's Avatar
2004 34' Classic S/O
Independence , Kansas
Furnace duct on 2004 34' classic slide out
Last winter I noticed a lot of warm air movement coming from under the kitchen sink. I thought maybe it's a nice feature to warm toes when washing dishes. But it's depleting the air flow in the ducts to the rear bedroom, hall and bathroom. Using my phone and camera I was able to determine that there is not a duct on one hole in the plenum. I don't mind a little bit of air there to help in the kitchen but any ideas on how to access that side of the furnace under the sink cabinet and at least partially plug that hole?
Thanks!
S/OS #069
2004 Classic LTD 34' SO Sofa
2015 Ford F350 SRW
Lthrncktrvlr is offline   Reply With Quote
Old 10-01-2020, 07:21 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The open area under the sink is the air intake. There is a removable panel above the opening, at least on my trailer. Before you plug it up, get the installation instructions and check for minimum air flow requirements. If you restrict the air flow below the minimums, the furnace could overheat and create a fire hazard.
Are you sure a duct didn’t come off? It makes little sense to have an output and the inlet in the same location.
Old 10-01-2020, 07:46 AM   #3
So far I have only done a minimal inspection using my flashlight and phone camera screen. I am not sure how to access the area to complete a more thorough evaluation.
Totally agree that it makes no sense for the duct to be open into the return air zone.
S/OS #069
2015 Ford F350 SRW
Old 10-01-2020, 12:00 PM   #4
So here's what I'm seeing under the kitchen sink, I have poked around, pushed and prodded on all the panels and can't find a way to get into the compartment to see if a piece has fallen out of that opening. Pretty sure it's not supposed to be just open like that though.Click image for larger version
ID:	379826Click image for larger version
S/OS #069
2015 Ford F350 SRW
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 8 04-15-2020 12:46 AM
Road side slide out slide out 02 x365Xl Land Yacht Dewey1966 Land Yacht/Legacy Motorhomes 0 08-21-2018 11:33 AM
Where is the heater duct to the fresh water tank on my AS? and furnace duct outlet ? ClayDC Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-08-2017 06:29 PM
To duct or not to duct! Flysoncloud Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-08-2010 09:22 AM
Slide Out Won't - 2004 Classic Stream 1529 2001 - 2005 Classic 9 05-28-2010 10:21 AM
