Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-18-2018, 09:03 PM   #1
1990 29' Excella
baltimore , Maryland
Furnace blower motor RPMs modified... is faster ok?
CALLING ALL MECHANICAL ENGINEERS !!!
I found a form - fit - function replacement blower motor for my Suburban NT-30k furnace. (original no longer avail)
All except the rpms. The new one is 33% faster. I thought that this would be fine, but now I am thinking the fire box running cooler could cause water vapor to not be totally ejected from the fire box?
I have read about corrosive problems that need special design considerations in high efficiency furnaces.
Would these things happen in my case?
Am I thinking correctly or worrying too much?
I dont want to have a rusted hole in the firebox halfway through the winter.
Thanks.
gh
groundhogy is offline   Reply With Quote
Old 10-18-2018, 09:26 PM   #2
Retired.
. , At Large
A resistor will slow the motor down, as will a potentiometer. Reducing voltage to reduce motor speed is an accepted method. Just make sure the method used is rated for the current used.
Old 10-18-2018, 09:49 PM   #3
1990 29' Excella
Yes, I think reducing the RPMs is the best solution too.
Going to need several power resistors. Have to drop 4 volts and 60 watts to get supply voltage and RPMs down by 33%. That is if Vsupply and RPMs are linear.
Old 10-18-2018, 11:34 PM   #4
2007 22' International CCD
A more efficient way would be a PWM adjustable speed control.
Old 10-18-2018, 11:54 PM   #5
1990 29' Excella
Yes, I have heard about using PWM.
What would this circuit look like?
Its got to take some heat.
How do you set RPMs on Onan 2800QG rowiebowie Generators & Solar Power 14 09-16-2018 08:37 AM
selling AO Smith 105 motor to replace original Armstrong blower motor eubank Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-07-2010 10:09 AM
Max RPMs for a 302? Boondocker Tow Vehicles 22 07-30-2007 07:26 AM
Rated tire speed - Can I get faster than 62? Goin camping Tires 1 09-25-2006 05:29 AM
Faster than a Telegraph! autoist Airstream Motorhome Forums 0 02-26-2003 09:32 PM
