Old 03-13-2020, 08:12 AM   #1
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Flying Insect Screens for Furnace
One of the last problems my Airstream's last furnace had was a yellowjacket nest which partially clogged up the works. To keep that from happening in the new Suburban NT-30 furnace I just installed, a set of exterior vent screens was purchased.
To my surprise the Installation Manual specifically states, "WARNING! Do not install screens over the vent for any reason. Screens will become restricted and cause unsafe furnace operation. Accessories are being marketed for RV products which we do not recommend. For your safety, only factory authorized parts are to be used on your furnace."
After weighing the pros & cons I still think the screens are a good idea. Anyone disagree?
Tom
ID:	363194   Click image for larger version
Old 03-13-2020, 08:40 AM   #2
1966 22' Safari
Fredericksburg , Texas
Have used those for years without issue. I just make sure they donít get clogged up with road debris.
Bubba L is online now   Reply With Quote
Old 03-13-2020, 08:43 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
Sorry, I do not have the same heater as you any more. I converted to a Precision Temp, Twin Temp JR.
However, I do use those same covers for my vent pipes on top of the trailer.
In My Opinion, As long as you keep them clean and clear there shouldn't be a problem. Once again free advice is worth what you paid for it. If it were me, I would use them. Leave them on until you want to use the furnace, then remove them if you are worried about it. They come off easy, or just undo one side at the time you want to use the furnace.
We have used these on a class A with no issues.
-Dennis
batman is offline   Reply With Quote
Old 03-13-2020, 09:28 AM   #4
2007 22' International CCD
I also installed a large rectangular screen over the whole integrated intake/exhaust vent on my furnace. I figure itís easy to clean and big enough to not block airflow.
Old 03-13-2020, 10:25 AM   #5
2017 19' International
Tallahassee , Florida
Here in bug-filled Florida, we use the screens.
Dealer strongly recommended them.
WhereStream is offline   Reply With Quote
Old 03-13-2020, 11:09 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The key is something called "equivalent opening area." You furnace exhaust has a certain cross-sectional area based on its diameter. The dome-shaped screens have a certain surface area based on their shape. As long as the surface area NOT filled by the wires of the screen is larger than the cross-sectional area of the original exhaust, the flow will not be restricted in any way, and the screens will not do any harm.
Old 03-13-2020, 11:52 AM   #7
SailorSam205's Avatar
South East , Michigan
At a rally sponsored by the manufacturer of my RV, we had a company representative make a presentation. He specifically brought this up. It isn't the RV manufacturer who has the requirement, it's the furnace manufacturer. The RV manufacturer is contractually required to enforce this specification. With all that said, he said that "If the screens are kept clean" there isn't an issue, however, if you bring your RV in for warranty service or send me pictures that will be used for warranty reasons, take the screens off first. What I don't know won't hurt you."
So keep the screens clean, even spider webs or tree floss can reduce air flow. And take the screens off before visiting your dealer.
Al
2017 29' SOB, 2019 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 03-13-2020, 10:52 PM   #8
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
I've screened my Suburban furnace to keep out the bugs. No problems last fall or so far this spring. I went with a rectangular one like below to have more surface area covered.
https://www.camperid.com/jcj/m200-rv...specifications
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 03-13-2020, 11:16 PM   #9
That looks like to one I used. Covers the whole vent assembly on the back of my trailer.
Old 03-14-2020, 06:32 AM   #10
2017 20' Flying Cloud
Williamson County , Texas
My dealer installed mine prior to delivery. Like said, easy enough to inspect them to make sure they are clean.
SYC2Vette is offline   Reply With Quote
Old 03-14-2020, 09:19 AM   #11
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Used them for years on my AS. Also, every spring I buy 2 large dog flea and tick collars and cut them into 3-4 " pieces and put them in every place that has an opening, water heater, fridge, heater, and hang one inside the propane tanks. No more bugs or spiders.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 03-14-2020, 09:26 AM   #12
Proud Owner Vintage SBB
'55 Airlight's Avatar
Santa Monica , California
Images: 105
I've got a screen over my furnace intake/output vent. But I couldn't stand the idea of the metal edge riding against my vintage aluminum, so I acquired some surgical tubing, sliced it and slid it over the metal edge so the screen rides against the surgical tubing which presses on the aluminum skin.
Michael
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,óthe three sister Graces of our moral being.í
Ė Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 03-16-2020, 07:28 AM   #13
1976 31' Excella 500
Chappell Hill , Texas
I use them for mud daubers and yellow jackets and have never had an issue with those bugs or the operation of the heater since. Make sure you get the ones that fit properly.
tbashin is offline   Reply With Quote
Old 03-16-2020, 11:02 AM   #14
2016 30' Classic
Houston , Texas
I use a screen very similar to the one in your picture. For the water heater, I have adhered a screen to the inside of the door. I examine them prior to beginning any trip. Reading your post will prompt me to be extra diligent in my examinations. I assume that the manufacturer's warning to not use screens is a liability management effort.
dhroberts is offline   Reply With Quote
Old 03-16-2020, 12:13 PM   #15
1981 31' Excella II
New Market , Alabama
They are fine. As Protagonist said as long as you are not changing the area of the inlet and outlet, you are fine. That is why the screens are dome shaped and/or standing off from the orifice. It is much more likely that you will have much more severe blockages from these insects. I just cleaned a furnace out and every orifice in the thing was clogged. The burner was full of dirt dauber nests and lady bugs. The actual gas jet was clogged with no see ums. You are far safer with a screen than without.
Perry
Insect Control In RV Camping Areas woodedareas Our Community 48 04-01-2019 10:48 PM
insect screen for 2015 FC Atwood Furnace? london1201 Winterizing, Storage, Carports & Covers 1 10-19-2016 12:02 PM
Flying insect screens Jstoutimore 2005 and newer - Bambi all models 0 09-27-2015 12:17 PM
Furnace insect screen TandT 2005 and newer - Bambi all models 2 05-28-2015 06:41 PM
Need Help cleaning our screens and vent screens ctalley316 Full-Timing 3 09-19-2008 11:48 AM
