Old 09-22-2020, 02:24 PM   #1
1988 25' Excella
Memphis , Tennessee
Electrical issue
So I set up my camper and everything worked fine had the ac goin went to bed, got up went to work the next day still everything fine went to bed woke up no ac. The pole tests fine and my outlets read 115. The fan setting will come on the ac but when I go to cool nothin. Its like I have enough to charge my phone and small stuff but not enough juice to do anything else. I do have a brand new battery. Sorry I tried searching but couldn’t really find the answer and electrics confuses me. Also 3 mobile repair people have replied “we don’t work on airstreams”
slawnugget is offline   Reply With Quote
Old 09-22-2020, 03:22 PM   #2
2019 27' International
Western NC , North Carolina
First thing I’d check is the a/c breakers for the unit(s). I would flip them off and back on to insure they are reset.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 09-22-2020, 03:35 PM   #3
1988 25' Excella
Memphis , Tennessee
Yeah I’ve tried that several times, not sure where to go from there. I do finally have someone coming to look. I just need to get it sorted before I role to night shift.
Old 09-22-2020, 03:37 PM   #4
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Like JonDNC said check the easy stuff first. If you have to any electrical checks inside the unit itself I found this You Tube video helpful in giving me an idea of what to do. I'm not an expert with electrical, but it helped me do some basics easily. He gets a little technical, but pay attention to the actual tests he performs.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 09-22-2020, 03:55 PM   #5
1988 25' Excella
Memphis , Tennessee
Great I’ll check the video out. I do hope it’s just the ac and not an electrical issue. I do need want to do some electrical upgrades but this was a last minute job I wasn’t even planning on pulling the camper to so I didn’t get to check or do any upgrades I was planning. I really do enjoy the amount of knowledge in this forum.
Old 09-22-2020, 04:12 PM   #6
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
You need 13+volts to run the electronic board in the A/C unit. Confirm that your converter is charging your battery, and that you have 13+ volts DC power to the unit. Your fridge also requires 13+volts to operate correctly on shore power.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 09-22-2020, 06:15 PM   #7
1988 25' Excella
Memphis , Tennessee
Ok he said all my power was good but the compressor is toast. So he’s putting a new one in tomorrow while I’m at work.
Old 09-23-2020, 12:45 PM   #8
1988 25' Excella
Memphis , Tennessee
Ok I think I’m fixed and the issue was electrical. Neutral was bonded at the hot water heater. So a bad instal of the hot water heater from when I worked in Mississippi cost me my ac and coulda burnt me down.
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Electrical issue? jornvango General Repair Forum 7 11-25-2012 07:55 AM
Electrical issue vicn2000 Electrical - Systems, Generators, Batteries & Solar 3 04-23-2012 06:14 AM
Help - electrical issue! mastercaster Batteries, Univolts, Converters & Inverters 21 04-09-2012 01:56 AM
2006 Safari Electrical issue Viper Batteries, Univolts, Converters & Inverters 7 08-17-2010 08:04 AM
