10-03-2019, 09:46 AM
1979 31' Excella 500
High Springs
ELECTRIC tankless water heater
We would like to put an ELECTRIC ONLY tankless water heater into our 1979 AS. Are there any recommendations you would suggest. The amp has to be less than 25. Thanks
10-03-2019, 09:51 AM
2019 19' Flying Cloud
Canyon Country
If you do not plan on boondocking, its a GREAT idea! Tankless with propane may be good for boondocking.
Get bigger tank if you plan to have guests over...
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
10-03-2019, 10:25 AM
Alamo Heights
If you're looking for something like an instaHot to give you hot water for a cup of tea, that's one thing. You're likely to be disappointed with the performance of any electric tankless unit you can run on a '70s Airstream's electrical system.
— David
10-03-2019, 12:32 PM
High Springs
Do you know of a tankless that you would recommend? Strictly tankless, no gas
10-03-2019, 03:20 PM
Alamo Heights
For my part, I'd never recommend a tankless electric water heater... they don't handle enough flow compared to their gas-fired counterparts. If you're setting up the trailer to be permanently parked somewhere and can get big power to it, there are 240V units that run 50A to 100A. Looking at a 75A/240v one, they claim a 31-degree temperature rise at 4gpm, compared to a midrange gas one that'll give you a 35-degree temp rise at 9.5 gpm.
A 30A/120v Bosch unit I found only delivers a 14-degree temp rise at 1.5gpm.
— David
10-03-2019, 05:38 PM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
janharrod,
What you're asking for probably doesn't make much sense. But if you insist, here's a place to find more information:
www.grainger.com
more specifically, my search results for 120 V electric, instant water heaters came up with the following page:
https://www.grainger.com/category/pl...&filters=attrs
As others have said, you may very well be disappointed. Then again, you're not me and I'm not you. Maybe one of these units will work fine.
May I go back a bit in the decision making process to understand why a 120 V electric, instant water heater is on your radar screen? Is there something about a conventional RV water heater that doesn't meet your needs? If so, there are other water heater systems that might work for you. Are you trying to avoid propane? If so, is there a reason why?
Check out the threads from SmokelessJoe - he used some interesting means of cooking, water heating, air conditioning and refrigeration. Maybe some of his techniques will work for you.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
10-04-2019, 12:17 PM
Ontario
, Ontario
The Stiebel Eltron DHC 3-1 is a decent unit. Don't expect high flows out of this unit, it is designed for point-of-use handwashing (0.4gpm). It draws 25 Amps on 120V and requires 10/2 AWG wiring.
10-04-2019, 01:16 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The gotcha is that water takes a lot of energy to heat. Heating a reasonable flow (like for a shower) up quickly .... yikes. If you switch the power system in the trailer over to 50A, you still will have "only" 240V at 50A. If you are running an A/C unit, you are down to ~ 35A at 240V for the water heater. That's not really enough ...
10-07-2019, 10:56 AM
Canyon Country
Janharrod, have you decided?
10-08-2019, 08:02 AM
High Springs
Thanks for all of the good advice....
We have researched and listened to everyone lots wiser than we are on this matter and have decided to go with the conventional water tank water heater. We think a 10 gal will do the trick. We're sorry that a tankless won't work but knowing how much we both love a HOT shower, we aren't willing to take a chance. Thanks to all of you for your great information!! Happy camping
10-08-2019, 08:27 AM
1986 31' Sovereign
Miami
Keep in mind that your basic RV water heater produces water that is much hotter than a household unit. It is not difficult to get a decent hot shower with one. The drawback is rebound time — you won’t get back to back long showers.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
10-08-2019, 01:02 PM
Canyon Country
How about 50 gal water tank?
10-09-2019, 08:44 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If the objective is simply a hot shower, why not go with a propane fired on demand unit?
10-09-2019, 02:38 PM
Canyon Country
Hi
I thought the same but he request for electric. Not sure why. Propane fired heats up water faster.
10-13-2019, 07:53 PM
1975 31' Sovereign
Forest Hill
, Louisiana
I would think physical size may become an issue on propane models? I have two electric instant-on heaters for kitchen sinks and they are both 60a/240v units that would not make for the hottest shower ever. They operate on "rate of rise" which is great in the summer, but in the winter not so much. I have a propane one for radiant floors and it is pretty big. I would love to be able to do the instant-on in my airstream, but more likely a small tank-type is the way to go for me.
10-14-2019, 08:16 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The reason for mentioning propane if it's just a shower issue is that propane fired boost units *do* exist for RV's. They aren't cheap, but they do exist.
