Old 02-04-2017, 03:00 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Ducted Air Register Removal
Anyone know how to get the vent covers off? I have the new operational and directional diffusers to install in their place but I can't get the old ones off. I will destroy them tomorrow if I can't find another way.
Ted S. is offline   Reply With Quote
Old 02-04-2017, 04:39 PM   #2
Ponyfvr's Avatar
2015 25' International
Scottsdale , Arizona
You have to work your fingers under a edge being careful not to bend the register. The register has little clips that hold it in place, the clips are made of plastic and if you can find one you can use a putty knife (preferably plastic so it wont scratch ) or something flat. We carry several of the plastic hotel "keys) that we use to open windows etc that would work. When you install the new vents look for the tabs and make sure that you get them firmly installed or the will fall out on a rough road (we learned the hard way). Good luck
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
Ponyfvr is offline   Reply With Quote
Old 02-04-2017, 06:43 PM   #3
2015 30' FB FC Bunk
Thanks Bob. That was my thought but they are really in there tight. I'll keep working them.
Old 02-04-2017, 09:47 PM   #4
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
X2 what. On said. I used a thin flathead screw driver to depress the tabs.
Troutboy
Troutboy is offline   Reply With Quote
Old 02-05-2017, 11:02 AM   #5
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Funny, I have the opposite problem, the registers keep falling out and I'm about to glue them up there! They have 8 little plastic tabs holding them or not holding them in. If you get two or more of them loose I'm guessing they will come out pretty easily. A small screwdriver or better yet thin putty knife will do the trick. Failing that I'm guessing just pullilng hard will do it. What are the new ones like?
jtwind is offline   Reply With Quote
Old 02-05-2017, 11:23 AM   #6
2015 28' Land Yacht
Houston , Texas
Directional Diffusers
Were did you purchase these vents and if I could ask what did they cost.
apanzer is offline   Reply With Quote
Old 02-05-2017, 11:40 AM   #7
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Very hard to remove, I finally use a screw driver, got my new ones from dealership.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 02-05-2017, 05:51 PM   #8
2015 30' FB FC Bunk
They were provided no cost from Airstream. I got them through my dealer, Colonial. The air over the bunk is just too much.
Old 02-06-2017, 06:28 AM   #9
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Some have used a heat gun to bend the tabs out a little more and give them a better bite.
The Colonel is offline   Reply With Quote
Old 02-06-2017, 09:43 AM   #10
dames7's Avatar
GILBERT , Arizona
Use a little duck tape around the on the tabs
David & Nancy Ames
2015 FC 25' RB
Old 04-30-2017, 07:52 AM   #11
2015 30' FB FC Bunk
Resolved.
So I ended up destroying the old registers to get them out. I must have had the ones that were beefed up after folks complained of them falling out. They were really fixed in good, no way to get them out otherwise. I had to push the screen in and unbend the tabs.
Ducted Air Roadtech Furnaces, Heaters, Fireplaces & Air Conditioning 530 07-15-2015 10:55 AM
Ducted Air Bassrats2 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-27-2014 05:52 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
