Originally Posted by Mbstrustee
Problem solved. The power connection on the battery for the thermostat was loose. Cleaned and snugged it up and it came on and the AC is now running fine. Fantastic fan still not working though. Thanks for all you suggestions.
Could you clarify what "The power connection on the battery for the thermostat was loose." refers to? Isn't the thermostat fed from the AC control board as explained by BayouBiker, which is fed from a 12v fuse protected circuit?
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
