Old 09-28-2021, 03:32 AM   #1
CMHM's Avatar
2021 27' Globetrotter
Malibu , California
Angry Dometic Penguin II: common issue - loud rattling
Hi all,
Just sharing an experience with two brand new Dometic Penguin II AC units. Upon turning on the AC I heard a very very loud metallic rattling coming from the AC.
As I was without a ladder I called a mobile RV repair guy and we realized the fan inside the AC unit came loose. We tightened a small bolt that holds the round fan unit in place and two weeks later the same thing happened again, on both units.
We used thread lock this time but I don' understand why such a large piece is held in place only by one single bolt - without any further safety mechanism. The first RV repair guy told me he is getting so many calls about this issue.
I have uploaded two videos, one from inside so that you can hear the noise. The second one showing the root of the problem.
Video from inside: https://imgur.com/cc3hhki
Video of the faulty unit: https://imgur.com/s7fQRc6
I thought it might be helpful for others as the sound it makes is absolutely scary. I also informed Airstream's customer care team.
Best,
S
CMHM is offline   Reply With Quote
Old 09-28-2021, 06:18 AM   #2
Sumterville , Florida
We are currently traveling with only one unit operable. Just before leaving we got the rattling sound. It turns out two fan motor bolts were very loose. The resulting vibration caused the third mount to break. Replacement motor and fan are a special order item.
SVTOTEM is offline   Reply With Quote
Old 09-28-2021, 06:35 AM   #3
2018 30' Classic
Williamsburg , VA
Where exactly was the bolt? Mine is making a noise nowhere near that bad but I'd like to get at it before it does.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 09-28-2021, 07:17 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
From the video, it looks like what is coming loose is the set screw that holds the fan onto the fan motor shaft, correct?
Old 09-28-2021, 09:37 AM   #5
1972 31' Sovereign
Dry Branch , Georgia
fan blade loose
Most fan blades are held on by two set screws 90 degrees from one another.
Your fan looks to be more loose than normal may have worn the hole larger.
It should not slide so easily with set screws loose.
Hopefully it will hold this time.
Buckless is offline   Reply With Quote
Old 09-28-2021, 09:50 AM   #6
JMHATX's Avatar
2021 22' Caravel
We just finished our first trip FC 23ft. I noticed our AC from outside way louder than both of our neighbors(both AS).
Also at night when the AC was running We had a pretty good rattle.
We we got home I cleaned up the coach and climbed up to inspect the AC unit and found a extremely loose motor mount bolt.(see attached picture)
After I tightened the motor mount the AC ran smoothly and quietly.
Is this a know AS issue??
Second - Part my Brother-in-law also just returned from a trip. I told him about my issue and he said he had an AC doing the same.
I went over and we climbed up and inspected his AC and one of his bolts were completely out. This fix was only a two beer job.
JMHATX is offline   Reply With Quote
Old 09-28-2021, 09:52 AM   #7
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Thatís pretty bad. I just replaced my motor due to excessive shaft movement. I changed over both fan assemblies and positioned both on the shaft to not cause any contact with housing. I tightened the single set screw on each as tight as I could get it. Hope I donít have your problem. It sounds like someone didnít tighten them during assembly. Also I would make sure the set screw is tightened on the flat part of the shaft.
The Colonel is offline   Reply With Quote
Old 09-28-2021, 10:40 AM   #8
CMHM's Avatar
Malibu , California
Yep, seems like this issue is very common. I am glad I turned the ACs off right away and hopefully it didnt damage anything else.
The bolt can be accessed through that little hole that you can see on the top of the fan unit, you need a long screwdriver to fix it.
Old 09-28-2021, 02:33 PM   #9
HoffmanP's Avatar
2014 27' FB International
Farmville , Virginia
Mud Dobbers
Check to see if mud daubers have built a nest in your two squirrel fans. That will throw the fan out of balance, and the ensuing vibrations will rattle bolts loose.
HoffmanP is offline   Reply With Quote
Old 09-28-2021, 11:28 PM   #10
YEP, every Spring.
Old 10-01-2021, 02:17 PM   #11
Florence , Alabama
Not sure about your's but mine uses standard setscrews that I had to use a long allen wrench, I think 1/8". Again, one needs to ensure it is tightened on the flat part of the shaft.
The Colonel and Southern Belle
Old 10-10-2021, 09:46 AM   #12
2020 27' Globetrotter
STAMFORD , Connecticut
I had this problem, climbed up, removed the cowling, and found that the squirrel cage/wheel was/is held in place by self-tapping screws that set into rubber vibration damping mounts.
I was astonished that they were self-tapping screws and not nuts and bolts with some threadlock and/or lock washers. I found one of the self-tapping screws in the base of the AC unit, screwed it back in, and checked the others, problem solved.
But, again, another example of poor design and quality control in the RV industry. I have three AC units on my boat (from the same company, Cruisair/Dometic), and they are built better.
Justinfinity is offline   Reply With Quote
Old 07-02-2022, 12:52 PM   #13
2022 23' Globetrotter
Temecula , CA
I just had this same problem, I was on a week long trip in our 2022 23GT and decided to run the ac on the 2 Honda 2000's for the first time. It started and was cooling, but there was a loud clanking sound. I shut down the ac to avoid damage.
When I got home I did some testing and got on the roof to inspect. I found one of the two bolts that hold the fan motor in place was not installed or backed out and was laying next to the fan motor. I screwed it back into the rubber "nut" and the problem was solved.
I will have to add this to my pre trip inspection list.
TBDOML is offline   Reply With Quote
Penguin I to Penguin II drain pan? HiJoeSilver General Repair Forum 1 05-25-2015 04:51 AM
Furnace Fan Rattling tmarquis Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-29-2011 05:32 AM
Rattling driver's door geomusic Land Yacht/Legacy Motorhomes 2 01-01-2011 11:59 AM
Should I expect some rattling from my Interstate? rv40 Sprinter and B-van Forum 12 03-18-2010 08:35 PM
Rattling pipes gandttimes Water Heaters, Filters & Pumps 2 09-19-2009 09:37 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
