Dometic Heat Pump Dripping Water through Ceiling Grill
The Dometic heat pump on our ten year old AS FC 23 works great, but is presenting water drippage through the ceiling grill of the unit after about 16 hours of operation (Photo 1). I ran a many hour test with the thermostat at 55F and first noticed water accumulating at the curb side’s rooftop mounting flange (Photo 2), and later on the street side as well, with minor streams of water running down the sides of the airstream in a few locations. I assume that the rooftop water accumulation is slowly making its way through the gasket of the unit (?). As for the water accumulating in the roof, there is a drainage tube in the front street side wheel well that was dripping water (Photo 3) which I assume is intended to drain condensate from the heat pump(?). If this is the case and the tube is partially clogged, it might explain the water accumulation on the roof. We bought the AS four years ago, barely used, and I assume the gasket has never been replaced.
Questions:
1) Should water be accumulating on the roof?
2) Could clogging of the drainage tube explain this?
3) Could leaking of the gasket explain the waiter drios through the inside grill?
4) Should I just have the whole unit replaced, or pay to have the gasket replaced and the drainage tube cleared out?
On an aside, the unit had just been serviced at our local AS dealership before our last trip, when we noticed the leakage. Thanks in advance!
