Old 11-27-2018, 07:49 PM   #21
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Originally Posted by AL’ UM- MONEY View Post
Recently installed a new Dometic with heat pump mode. This summer massive water drained out the new drain line in the wheel well on AC as advertised. Recently we ran on the heat pump cycle and water runs down the side of the AS and not from the drain. Any suggestions. I assume the heat pump cycle doesn’t generate much or any condensation
This issue is discussed here>
http://www.airforums.com/forums/f427...ml#post2171453
Alan
Old 11-28-2018, 09:55 AM   #22
1981 31' Excella II
New Market , Alabama
Has anyone removed the cover to see where the water is going? I mean the outside cover but removing both would be a good idea and let it run till it drips. Might be a hole rusted in the pan somewhere. If there is no condensation recovery system the water still should not leak inside the trailer.
Perry
Old 11-28-2018, 10:53 AM   #23
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Originally Posted by spark01 View Post
Mine is 2018 FC 28RBQ with two AC units and I have noticed water on the floor a couple of times -- once in AC mode and just last week, in heat pump mode. Since the bedding is not wet and there is no drip mark on any duct openings above, I have no idea where the water is coming from. However, I'm pretty certain that the leak has nothing to do with rain. We've had some heavy downpours but this Airstream is rain-proof and no problem there. My guess is it's the condensation leak from the AC unit, but I can't figure out how it get down to the floor without dripping on the bedding. All vents are over the queen bed. Any idea?
Hi spark01,*
Congratulations on your new Airstream! Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 11-29-2018, 07:39 AM   #24
2018 28' Flying Cloud
Thank you.
spark01 is offline   Reply With Quote
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Exterior heat pump condensation or leak? bonginator Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-23-2010 10:16 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
