Old 08-16-2019, 09:48 AM   #1
2019 27' International
Niederwald , Texas
Dometic E7 Error
I have an 2019 Airstream Serenity 27FB with dual Acs. The rear AC is throwing an E7 error (loss of 120v). Front AC is working fine.
I tripped the breakers and reset the thermostat.
any suggestions would be great!
Art
ArtBro is offline   Reply With Quote
Old 07-22-2020, 05:42 PM   #2
Fountain hills , Arizona
Hi there,
I am experiencing the same issue. Did you ever figure out what the issue was?
2017 27' Tommy Bahama
Arizona Bob is offline   Reply With Quote
Old 07-22-2020, 05:50 PM   #3
2018 27' International
carbondale , Colorado
Me too. Would love to know what the problem/ answer was.
capt_ron777 is offline   Reply With Quote
Old 07-22-2020, 08:02 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I only have 30 amp and 1 A/C, but every time I have gotten an E-7 it is simply because my main 30 amp fuse has popped. I cannot run the induction burner if the A/C is on and the water heater and refrigerator are on electric. Normally I remember to turn the water heater off before making morning coffee but get only about 5 seconds after hitting start on the burner to say, oh crud... and reset the alarm clock.
Old 07-22-2020, 09:47 PM   #5
St. Marys , Georgia
Our E-7 code would not disappear with multiple resets of the thermostat--eventually determined cause bad power connection at the roof unit.
peggy2ten is offline   Reply With Quote
Old 07-22-2020, 09:59 PM   #6
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Dometic E7 Error
Assuming you are not at a campground with truly awful voltage <109v......
If resetting breakers and ccc2 unit do not correct the issue it’s very likely you have a an issue with a physical/mechanical connection either in the junction box in the ceiling (need to remove return registers to investigate - I believe there is a connection made below the intake) or at the main board outside in the AC itself (need to remove the shroud to access the main board)
Check those out quickly as a next step.
PS - also check the physical connection of the wiring at the breaker itself in your panel.
wulfraat is offline   Reply With Quote
Old 07-23-2020, 08:40 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
If you have a 50amp plug (which you certainly do if you have two ACs), it is possible that your campground pedestal may be dead on one leg.
Try using a 50-30 dogbone, plugging into the 30amp side, and then trying only the ac that hasn't been working. If it now works, then you know the problem is with the pedestal.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Dometic RM3762 Error code E1 help Airstream01 Refrigerators 20 01-28-2019 11:01 AM
Dometic AC Error Codes Morgan guy General Repair Forum 6 10-01-2017 11:05 AM
Dometic refrigerator error code e0 lgring 2011 - 2015 International 0 02-12-2016 07:55 PM
Help: Dometic on heat shuts down; Error E3 LAWBC Electrical - Systems, Generators, Batteries & Solar 7 09-28-2014 12:23 PM
Dometic Error E7 S3d Sprinter and B-van Forum 4 08-27-2014 05:46 PM
