Dometic Air Distribution Boxes
The Dometic shroud #2 was not delivering enough cold air to the front of the trailer. The shroud has 4 vents and in my view is designed for newer RVs with 2 A/C units and slide outs to provide cold air in a square pattern as opposed to the 2 vent rectangular pattern needed for older RVs with a single A/C unit and no slide outs. My RV shop retrofitted a Coleman low profile shroud with a front and rear vent and it works great and delivers the cold air to the ends of the trailer. The 15,000 BTU is a noticeable improvement from the 13,500 BTU Armstrong. I ran it in 100 degree weather and it did the job fine.
