Originally Posted by lsbrodsky
Were modifications required to install the Blizzard or did it just bolt in where the Penguin II attached?
Larry
The Blizzard fits the existing roof opening. The blizzard installs using a dense foam gasket & tie-down bolts. You need to order the drain kit and have a couple drain tube fittings however the existing drain tube works fine. You will also need to install the correct thermostat regardless of having one or two A/C units. The biggest hassle is getting the old A/C off. Airstream basically glues the factory installed Penguin II onto the roof.
