Old 04-08-2020, 12:37 AM   #41
2014 27' FB International
Lewisville , Texas
This is not a new issue, see here and others.
https://www.airforums.com/forums/f42...ng-194919.html
NO NOIZE is offline   Reply With Quote
Old 04-08-2020, 06:14 AM   #42
2000 23' Safari
Dalla , Texas
We had to replace one of our units a couple of years ago on our 2015 flying cloud. Maybe it helps them make the case to sell more extended warranties
MilosPop is offline   Reply With Quote
Old 04-09-2020, 06:39 AM   #43
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
About 4 years ago one of the two Original Dometic A/C units on my 2004 - 34' classic bit the dirt. I had two Dometic Blizzard A/C's with heat pumps installed. So far they have been terrific. They are much quite then the Penguin II. I've got no idea why Airstream continues to use the old Penguin II technology.
https://youtu.be/FKfvMwhf784
NOAZRK2690 is offline   Reply With Quote
Old 04-09-2020, 06:46 AM   #44
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Were modifications required to install the Blizzard or did it just bolt in where the Penguin II attached?
Larry
lsbrodsky is offline   Reply With Quote
Old 04-10-2020, 05:44 AM   #45
NOAZRK
NOAZRK2690's Avatar
Larry
The Blizzard fits the existing roof opening. The blizzard installs using a dense foam gasket & tie-down bolts. You need to order the drain kit and have a couple drain tube fittings however the existing drain tube works fine. You will also need to install the correct thermostat regardless of having one or two A/C units. The biggest hassle is getting the old A/C off. Airstream basically glues the factory installed Penguin II onto the roof.
Old 04-10-2020, 06:27 AM   #46
lsbrodsky's Avatar
Thanks, just curious, war-gaming the future.
Larry
Old 04-10-2020, 08:22 AM   #47
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Originally Posted by mikesSE View Post
My ‘07 Safari’s Penquin 600 lasted nine years,then it over-amped in a small campground(low voltage).I replaced it with a new Penquin 2,then one month later,replaced it again,with another Penquin 2. The trust in Dometics is GONE.I bought extended warranties,but that is adding costs to the product that we consumers don’t need to bear.If It had a way to remove condensate drainage,I would buy a Coleman.Actually I and thinking of a remote unit to get it off of the roof,where it’s noise doesn’t drone so bad.Space problems with a 23ft.comes up.
I went through 2 penguins in a month before getting a Coleman Mach. I added a condensation pump and it works great.
Ian
Iansk is offline   Reply With Quote
Photos from the RV Junk Yard...a must see! tin can luv Exterior Restoration Forum 43 06-17-2004 10:49 PM
New 50 amp Cable~JUNK Navigator Electrical - Systems, Generators, Batteries & Solar 3 04-28-2004 11:32 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Airstream junk yard???? McGill General Repair Forum 7 07-04-2002 03:32 PM
