Old 07-16-2020, 09:20 AM   #1
1976 31' Sovereign
houma , Louisiana
Does the roof need to be reinforced for 2 A/C units ?
I recently picked up 2 dometic penguin low profile ac units for my airstream - A 1976 31foot sovereign. I was originally only going to put in one unit but I got 2 for the price of one at a surplus sale, and living in south Louisiana the heat and humidity are just about as bad as it gets.
My question is what needs to be done to the roof to install 2 units. I don't want to cause a weight issue. I want to put the second unit on the rear of the trailer where the old vent is. This trailer undergoing a large restoration project so adding bracing would not be hard but I would like to hear from some of you who have done this already.
Jacques
CajunCan is offline   Reply With Quote
Old 07-16-2020, 09:59 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Check with Out of Doors Mart in NC. They sell (or did sell) a reinforcing frame for use when replacing a vent with an AC unit.
And yes, the roof does need reinforcing. At least newer trailers do.
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Old 07-16-2020, 11:58 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yes. Aluminum c channel, riveted top and bottom and vulkem between the outer and inner aluminum sheets.
Or some really good wood, completely tape / seal with gorilla tape And use large pan head screws and vulkem. This is how I added our second ac on our 34’, 1999 8 years ago..
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-31-2020, 07:04 AM   #4
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
cwf, Any pictures? What dimension (gauge, width, edges, etc.) C channel did you use for this? I'm afraid I'm not able to visualize what you mean by riveting top and bottom. Would you mind breaking your install down a bit for us short bus kids.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 07-31-2020, 05:09 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy, Pete.. That was several years and storage platforms (clouds) ago... let me try to locate..
I did an Airforums search with words "AC bracing".. here is one with a good view to help:
https://www.airforums.com/forums/f42...it-192585.html
Channing
WBCCI# 30676
Old 08-03-2020, 12:43 PM   #6
Re-Pete's Avatar
1992 29' Excella
Channing,
Thanks!! This looks good. If you remember anything else that might be helpful I'm all ears. BTW do you remember where you bought the Aluminum channel you used on your opening?
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
Old 08-03-2020, 04:25 PM   #7
Central , Mississippi
Here is how we added a second ac.
https://www.airforums.com/forums/f20...tml#post839907
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 08-03-2020, 09:41 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Pete..
Hope you guys are high and dry.. the storm's a comin'..
I used treated wood then wrapped in Gorilla tape.
I do not at this time remember precisely the dimension. I am thinking it is about 2" square. It just needs to keep the two skins apart. I then put the Vulkem on the inside aluminum sheet, slid the boards into place, clamped to stop movement then screwed down with broad shallow panhead screws. I put 6 per side. Make sure you cut the boards correctly because you need to account for best fit.
Ping me if you want more ideas...
Channing
WBCCI# 30676
Old 08-07-2020, 06:44 AM   #9
Re-Pete's Avatar
1992 29' Excella
Pete..
Thanks Channing,
We weathered the storm just fine. I have a feeling we might be in for a few more this season.
I appreciate the additional detail. Somehow I misunderstood what you originally posted. It's crystal clear now.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
Body on Frame reinforced hitch tnguyen Towing, Tow Vehicles & Hitches 0 01-26-2020 08:52 PM
reinforced frame walleye001 General Repair Forum 1 03-18-2016 12:40 PM
I Need Photos/Diagram of Reinforced Mercedes Hitch jonnie3 Hitches, Couplers & Balls 8 05-05-2015 01:14 AM
Fiberglass Reinforced Panels........ RV H-D Lady Sinks, Showers & Toilets 2 11-09-2010 07:15 PM
Fiberglass Reinforced Panels........ RV H-D Lady Upholstery, Blinds, Walls & Interior Finishes 3 11-07-2010 05:14 PM
