09-15-2024, 02:15 PM
2006 25' Safari
St. Augustine
Different Ways to Lift an AC unit on the roof!
Greetings!
I was all about using a scissor jack at my church to lift the AC units off/on the roof but am hearing they do not have one. I have seen one but I dunno.
So, I need ideas for getting those things moved. Any thoughts. I am alone but I will have to find help most likely.
ALSO: DRAIN accessory on Dometics
When you flip the AC upside down, did you do that with or without the shroud on? Which is better?
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
09-15-2024, 03:08 PM
Keys Dave
2021 25' Flying Cloud
Big Torch Key
, FL
Originally Posted by rodsterinfl
Greetings!
HD has a material lift for rent. It's a manual device for lifting up to 450 lbs. up to 12 ft up. It rents for about $80. for 8 hrs . It's cantilevered on wheels like an engine lift so it can roll right over the top of the AS if you are on a paved area.
09-15-2024, 05:45 PM
2010 30' Classic
Warren
, Manitoba
I got my neighbour to come over with his skid steer and a good pallet. Lifted the old A/C unit onto the pallet, lowered to the ground. Cleaned up the opening and removed all the old caulking and lifted the new unit back up on the pallett. I used some thick cardboard under the new unit and left it under until close to the opening. Repeated for the rear A/C unit. Total time less than 1 hour. Gave him $100 and everyone was happy.
Then had friend on the inside, and me on the roof, and centered the units correctly and bolted down with the interior plates. Total time for each A/C was about 1 1/2 hours till turning on and checking. My units do not have the drain hose commections..
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
09-15-2024, 10:44 PM
1995 25' Excella
xxxxx
, xxxxxx
Put a piece of carpet on roof, lay an extension ladder at about 45 degrees up to the roof. Slide the AC up/down the ladder on a piece of plywood.
09-16-2024, 11:20 AM
TorpedoFamily
2014 30' Classic
Ozark
, Alabama
Before installing the new unit if it has the condensate drip pans on the front PAINT them to protect form UV deuteriation.
09-16-2024, 02:05 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
When I had one done by a mobile RV tech he stood on the roof and on a ladder and his wife just picked the AC up and handed it to him. I was impressed with the strength but worried about the roof and AC unit. It came out okay.
09-16-2024, 02:20 PM
1994 25' Excella
Waukesha
, Wisconsin
Used a block & tackle hung from a rafter in our barn where the trailer is stored. Lifted the old a/c and then backed the trailer out so we could lower it down. We then got the new a/c strapped in for the ride and while it was still near the floor I connected the drain kit. Then it was hoisted up and we pulled the trailer back in. Once I hit the same parking marks the new a/c lowered right into place.
In the photo you can also see the ladder setup I use to get on the roof.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
09-16-2024, 03:08 PM
2018 16' Sport
Tacoma
Here's a way ......
Tow vehicle, extension ladder, plywood sled.
2011 Ford Explorer Limited with factory tow package
2011 Harley-Davidson Ultra Limited
09-16-2024, 05:30 PM
2016 28' Flying Cloud
Dover
, Pennsylvania
I changed mine out a couple months ago. I used 2 ladders leaning against the trailer and a 2x10 between them. It was pretty easy with 2 guys on ladders and a 3rd guy on the ground. Really didn't need the 2x10 and could have gotten away with just 2 guys on the ladders but the 3rd guy did make it easier.
09-16-2024, 09:10 PM
1994 30' Excella
alexandria
, Kentucky
Lay some cardboard or dropcloth down on the ground, keep the shroud in place, flip it upside down and a put the drain kit in place.
I have used different methods to put it on the roof. A strong guy shoving it up a ladder works well.
2009 Dodge 2500, 6 Speed Auto, CTD, Quad Cab, Short Bed, ARE cap, Bed Rug
Propride 3P Hitch
WBCCI # 3072 Airstreaming since 2008
09-22-2024, 10:18 AM
Airstream - Other
Milton
What about the gasket that has to be replaced if torn?
09-22-2024, 12:48 PM
2018 30' Classic
Jacksonville
On the Airstream I'd put the AC on a pallet on the forks of my tractor and lift it up/down. On your church I'd use a crane or helicopter depending upon size of the church and roof top units, RTU.
09-22-2024, 03:00 PM
2009 22' Interstate
St. Paul
Greetings!
Try to find someone with a forklift.
09-25-2024, 07:44 PM
2006 25' Safari
St. Augustine
Ok, Thank you for so many great ideas. I checked on a lift and that went nowhere. We ended up getting three ladders. We have a long extension ladder so we used that as a ramp and then I got a neighbor and my father to come out and act as spotters and push, each on their own ladders while I was on top. We thought of using the ladder in the truck bed method (Runnamok13) but it ate up the room for us to work so we just did it a simple way. It worked well. We strapped and tied the unit in its box with the sides pre cut and pulled it up. At the top I only had to lift it on its side, slide it on the cardboard into position and then pull out the cardboard- no sliding on gaskets, etc.
Getting the old one off was rope and ladder- note the caulk that is just a portion of what was on the unit, the pan, etc. it was crazy caulk day back when this thing was built/assembled!
There was one casualty. My father, not thinking about the Airstream, was getting his ladder footing solid on the ground and was rocking it against the Airstream not thinking about the metal as I went to get the rubber shield mat. He scratched it, not severely but still. I will deal with it but hey, some "pros" have really done some damage to Airstreams I have heard. I dont like the scratch but I am thankful for the help.
It is a big job. There are several errors in the Blizzard NXT Manual. I discovered the metal plate that is used to bolt in the unit (the BCGH) alingnmnet holes are NOT what to use even though it states as much.
