Old 02-19-2024, 07:59 AM   #21
bellingham , Washington
Originally Posted by Adventure.AS View Post
25' RB Serenity
Fireplace installed on the refrigerator bulkhead (TV removed), at the end of the lounge.
Attachment 283104
The flue is double walled with the exhaust on the inside and combustion air coming down the outside. The chimney is warm to the touch, but likely won't burn unless you grabbed a hold for several seconds.
Attachment 283105
Chimney cap is low profile and as it is designed for the marine environment will keep out the rain.
Attachment 283106
The fire adds lots of heat and ambiance.
Attachment 283107
The propane line was tee'd outside the coach and then the run through the refrigerator compartment and through the bulkhead. 12 volt power to run the fan was also brought through from the bulkhead.
Did you have any issues sealing the vent cap considering the cap is flat and the camper is curved where the vent goes through?
Bryan - BellinghamWA
bweener68 is offline   Reply With Quote
Dickinson propane heater placement Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 17 02-19-2024 09:30 AM
Dickinson Newport P9000 Propane Fireplace Adventure.AS LP Gas, Piping, Tanks & Regulators 7 06-14-2016 03:51 PM
Dickinson Propane 'fireplace' installed barts Furnaces, Heaters, Fireplaces & Air Conditioning 14 01-19-2014 02:25 PM
Dickinson Marine Newport propane heater/fireplace bgordon Furnaces, Heaters, Fireplaces & Air Conditioning 7 12-12-2012 02:02 PM
Propane Fireplace for Globetrotter B Stover Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-18-2005 05:42 PM
