Old 09-18-2023, 02:37 PM   #1
2010 23' FB Flying Cloud
Smithville , Texas
Condensate not draining. Codes E7
Our Dometic AC was replaced at AS Boise in 2019. Technician said he was having trouble connecting condensate drain. It worked pretty well for quite a while but recently started coding out.
Sometimes it drains, sometimes it doesn't. We try different level placements but it's hit or miss. After it dries out the AC works again, sometimes for weeks, then it fails to drain properly again. We have repositioned the trailer when it's not draining. Sometimes this works, sometimes it doesn't.
How do I simply allow it to drain onto the roof? When it works properly, the condensate drips down by the front axle. I can't find photos or diagrams to know if I have a pan or what is up there to channel condensate.
We bought out 2010 FC 23FB new, and it has at least 100,000 miles now. If I remove the cover, will it be obvious how it is SUPPOSED TO DRAIN.
I am no mechanic, but tackle jobs I can find instructions for. Replaced water heater, and furnace myself. I haven't found any threads with my issue.
Any help will be appreciated.
Matt & Virginia Kline
2010 FC23FB
2016 F-350 6.7 Diesel (Overkill and loving it)
Matt Kline is offline   Reply With Quote
Old 09-18-2023, 05:51 PM   #2
1988 32' Excella
Robbinsville , New Jersey
I think your trailer would have come from factory with a drain pan, since the tech was having trouble connecting the condensate drain it was probably changed to drain cups.
You would probably need to take the interior parts off to see how it is set up.
Many of the older AC units would keep working and just leek into the trailer when they stop draining properly.
A/C condensate running off the roof... NOT out of the drain tube RFP Furnaces, Heaters, Fireplaces & Air Conditioning 141 10-29-2020 04:14 AM
water entering airstream from around dometic air conditioner, not condensate water Lucky Tom Furnaces, Heaters, Fireplaces & Air Conditioning 13 09-04-2018 07:24 PM
Air Conditioner Condensate Draining Inside Camper bigbuck1962 Furnaces, Heaters, Fireplaces & Air Conditioning 9 11-14-2016 10:26 PM
Color Codes for a 1976 Argosy 22' ray matthews Clearcoat, Exterior Paint & Trim 11 01-01-2012 01:15 PM
Blue Trim Color Codes John W Clearcoat, Exterior Paint & Trim 3 01-03-2005 10:33 AM
