Old 10-21-2018, 01:59 PM   #1
2019 25' Flying Cloud
Tucson , Arizona
Checking Thermostat Questions
Howdy,
Brand new 2019 Sport 22FB. Every time I go to check if furnace is working properly it's 90 and at least that hot in the AS. It seems the stock Dometic analog thermostat won't allow the on/off switch to even move if...
It's warmer than the extreme heat of the device. For instance it's not gonna allow heat when it's 90.
And/or
The propane and pilot light are off.
I figure at least the on/off switch would move but it's locked in Off position. SHould it be in above scenario?
I'll wait for a cooler day to try it, turn on propane and pilot light.
But meanwhile the thermostat is old fashioned at best! Is it easy to upgrade to a digital? Recommend an good direct replacement?
Rounder44
Rounder44 is offline   Reply With Quote
Old 11-05-2018, 09:37 PM   #2
Eric
tucson , Arizona
Rounder44 ..I have a 2006 Safari 23 ..similar question, looking for a direct digital replacement .. BTW ..I'm in Tucson!
laferic is offline   Reply With Quote
Old 11-06-2018, 08:10 AM   #3
Tucson , Arizona
I bought this one!
Honeywell TH1100DV1000 Pro-Digital 2-Wire Heat Only. $30 on Amazon.
Installed quickly and works great!
Any good RV resources in Tucson besides the typical Camping World etc?
HTH
R44
Old 11-07-2018, 09:11 AM   #4
Eric
tucson , Arizona
R44 .. Thank you so much .. Oasis RV on benson hwy .. they are super good .. just ensure you have an estimate before any work .. a lot experience with AS .. Joe, the owner used to work for AS (long time ago) .. and Richard is the best!
Old 11-07-2018, 09:52 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There's no real guarantee that the issue *is* the thermostat. Since we are talking about a 2019 here, it's still very much in warranty. Fiddling things / DIY stuff can get you into warranty issues ( = they will not be happy fixing any mistakes you might make). I'd get the original fixed first. Once it's working correctly *then* play with replacements. Going from "working" to "working" is much easier than trying to do multiple things at once ....
Old 11-07-2018, 12:07 PM   #6
Tucson , Arizona
Hi
Mine was working but very stiff and hard to read the gauge.
The digital is MUCH simpler especially with the placement AS chose.
R44
Old 11-07-2018, 12:08 PM   #7
Tucson , Arizona
Oh yea!
I went there looking at used AS but decided I don't have time or place to refurb one and went new.
I'll check them out for odds and ends though.
R44
Penguin II and CCC2 thermostat install questions Greg1410 Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-20-2019 10:37 PM
Dometic RM 100 120/propane fridge questions(thermostat setting plus fan upgrade) Jjona5 Refrigerators 15 08-04-2017 07:20 PM
Questions on thermostat and distribution box Ora Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-06-2016 09:33 AM
AC thermostat questions desertair27 Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-21-2011 05:33 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
