Old 06-27-2017, 07:59 PM   #1
1989 32' Excella
Sharon Springs , New York
Changing A/C capacitor to ease start up power draw
Greetings, I thought I saw an article in either Airstream Life or the WBCCI Blue Beret magazine that talked about changing an A/C's capacitor to ease the start up draw on the TT's power system. If anyone has seen this write up, could pass along which publication and what month it was in. Also, any opinion on this procedure would be appreciated.
MAJORJDB is offline   Reply With Quote
Old 06-27-2017, 08:07 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Many of us have done this upgrade and it works great. Reduces startup load / amperage draw from the compressor by 60-70%. allows you to run a 15k AC on using a single Honda or Yamaha 2000 watt genset.
Search "Micro Air" or "EasyStart" and you will find a number of threads on this topic.
Here is the product page. You can download installation manuals / videos:
https://www.microair.net/products/ea...nt=30176048267
wulfraat is offline   Reply With Quote
Old 06-27-2017, 08:31 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
I suspect you both may be talking about two different solutions to the starting surge issue. Of the two, I'd go with the "electronic" solution rather than just a capacitor swap.
Old 06-27-2017, 08:56 PM   #4
wulfraat's Avatar
The Micro Air EasyStart is a software-driven device that replaces the start capacitor in the AC unit.
Note that the EasyStart does in fact have a traditional Start capacitor inside the enclosure, however current is regulated by the software installed on a control board, which is also located inside the enclosure.... So it is far more effective at reducing startup load vs a traditional start capacitor or traditional hard start device.
Old 06-27-2017, 10:14 PM   #5
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
I used the Micro Air upgrade last week. It works well even though I am using a somewhat larger (Yamaha 2400) generator. The hardest part was getting the old hard start capacitor out. It was apparently installed into the electric box before the box was installed into the a/c.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 06-28-2017, 12:31 PM   #6
1973 25' Tradewind
Redding , California
so...
If you were going to do this upgrade, It is best done before the AC is installed? or does it matter?
Leadvox is offline   Reply With Quote
Old 06-28-2017, 12:32 PM   #7
2007 22' International CCD
Depends on how you feel about working on the roof of the AS in the hot sun[emoji3]
Old 06-28-2017, 12:36 PM   #8
UnklJoe
2015 28' Flying Cloud
Box Elder , South Dakota
Link to Capacitor Discussion/URLs
Try this thread:
http://www.airforums.com/forums/f448...-108614-3.html
There are some good links to URLs about capacitors for A/C starting.
Hope this helps!
UnklJoe is offline   Reply With Quote
Old 07-01-2017, 08:01 PM   #9
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands , Illinois
Yes there was a thing about this and I have replaced mine. The artical was I think last year, but do not remember when. Go to the WBCCI Blue Beret and look in the past.
rmatkovich is offline   Reply With Quote
Old 07-01-2017, 08:06 PM   #10
2000 34' Limited
1985 25' Sovereign
I had a 2200 watt and will not run my air with the new capacitor. need a 2500 +
Old 07-05-2017, 05:38 PM   #11
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
I run my air conditioner with a Honda 2000 watt generator in its "ECO" mode. Instead of upgrading the generator, go with the Easy Start. It's more expensive than just buying a capacitor, but it does a fantastic job. It revs up my generator before starting the AC compressor.
Glenn T is offline   Reply With Quote
Old 07-07-2017, 02:11 PM   #12
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
If you are still interested the BB article was in the June 2016 issue. It advised to use the Supco SPP6E capacitor. On Amazon I find this one listed as well as a SPP6. I'm not sure which route to go replacing the capacitor or going the Micro air route. The price is a bit steep for the Micro air however.
Since the article recommends the SPP6E I suppose I'll go that route for the price and ease of installation
Hmmmm. Still pondering
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-07-2017, 02:28 PM   #13
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Yes, it is good to do that as it protects the compressor too. I replaced mine and learned in the process that Dometic updated the specific capacitor for my unit to a more powerful one.za It sounds different when it starts now. Less drag on startup. It used to have 4-5 seconds of grunt then blow. Now about half that. I would check with Dometic before just replacing it if you own a Dometic. I found my old part number available but from limited vendors which led me to wonder and then call to learn the new number and part.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Old 07-07-2017, 02:31 PM   #14
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
No starting cap. replacement is going to let you start the A/C on a 2000 watt genny. If your genny is bigger, have at it. But I have to say, the lack of the big clunk when the compressor starts, using the Micro-Air, is worth it. You just know the compressor is happier.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-07-2017, 02:44 PM   #15
retired USA/USAF
2001 30' Excella
I have a Honda 3000 generator but as yet have not needed to use it to run the AC. Our major dry camping has been in the Fla. Keys in Jan/Feb and AC is usually not needed then. Summer camping seems to usually have electric hookups or out west at higher altitudes and don't need AC their either.
Roger in NJ
TAC - NJ 18
Old 07-07-2017, 04:32 PM   #16
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"Also, any opinion on this procedure would be appreciated."
My opinion: forget finding the article or trying to just change the start capacitor. Go with the Easy start. I am pretty cheap overall but I did the Easy start and am happy with it. I do not think you can do it with just a start capacitor.
At least go to the Micro Air website and read the promos for it.
Old 07-07-2017, 04:44 PM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Picking up the Micro-Air after I arrive in Escanaba for the International. Going to take advantage of the free install by the company owner and Lew. I have a new Penguin II 1500 w/heat pump. It noticeable starts easier and is much quieter than the previous Penguin.
MICHAEL
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 14 01-20-2023 05:44 PM
Hard start capacitor for A/C egraham Electrical - Systems, Generators, Batteries & Solar 2 07-04-2016 03:33 PM
Installing pole ease flag holder on new AS yakman General Repair Forum 30 11-02-2014 11:12 PM
Start capacitor for Armstrong 14 A/C pdwhitt Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-04-2011 04:01 PM
pole-ease flag holder question Chuck General Repair Forum 9 10-07-2008 01:20 AM
