Old 05-05-2017, 11:33 AM   #1
QC TORPEDO's Avatar
2017 25' Flying Cloud
Queen Creek , Arizona
Ceiling A/C registers
The round slotted things that the ducted air conditioning comes out of don't allow much cold air to come into the trailer. Has anyone altered or replaced these registers with something that allows greater air flow? I read a post where someone just left them off when they fell off and seems happy with the improved cooling. Any suggestions or ideas?
QC TORPEDO is offline   Reply With Quote
Old 05-08-2017, 11:28 PM   #2
Granbury , Texas
I'm with you QC...the registers are terrible. When airstream first came out with ducted air they didn't use adjustable registers...just screen mesh like the return vents have.
I think the original mesh had better air flow but people complained they weren't adjustable so they supposedly improved them...fast forward to the new and improved adjustable registers that cut air flow and fall out of the ceiling.
cabinetmaker is offline   Reply With Quote
Old 05-09-2017, 04:53 PM   #3
2017 23' Flying Cloud
Lakeport , Michigan
Agree that the air flow is weak. Also a couple of them keep falling off. While stationary. Hit my wife in the head while she was standing in the galley.
Motown is offline   Reply With Quote
Old 05-17-2017, 09:02 PM   #4
QC TORPEDO's Avatar
Repair idea
I am on the verge of a breakthrough for the replacement of the ceiling registers. While testing replacement ideas, one register kept falling down. I drilled out the rivet and took it apart. Using a piece of aluminum channel to span the opening from the inside, I put a jacknut in the channel and used a screw through the center hole in the register and screwed the thing to the ceiling. It can still be directed if the screw is loosened and re-tightened.
I have two shower drain covers on order and I will use them in the same manner. They just have holes and no directional louvres. I should get good down draft where its needed. The only concern is balance between front and rear registers (only one A/C unit). If it is a problem, I may change out the rear registers too.
If this works, I will post the result. If not, I will retreat.
Old 05-29-2017, 09:36 PM   #5
QC TORPEDO's Avatar
Solution
parts
stainless steel floor strainere drain cover bath sink filter 6 inch - amazon - use the search term above
6-32 short jacknut - hardware store
1 3/4 “ 6-32 screw
3/8” aluminum trim channel – hardware store
preparation
cut aluminum channel to 7”
drill 5/16” hole in center of cut aluminum channel
push jacknut in and expand
drill .136 (#29) or .140 (#28) hole in center of drain cover
bend a 10” piece of stiff wire to hold the work during installation so you can pull down on the channel while turning the screw
installation
start screw through drain cover and into jacknut in the aluminum channel
remove existing vent register
install the channel, spanning the hole
using the wire to hold the channel to the inside of the duct, tighten the screw so the new duct holds tight to the ceiling.
test
great airflow to the dining area below the ducts! :d
Old 05-29-2017, 09:50 PM   #6
Granbury , Texas
Originally Posted by QC TORPEDO View Post
parts
1 3/4 “ 6-32 screw
preparation
installation
test
Pictures??? Sounds interesting...we haven't had any of ours fall yet but want to be prepared.
Old 05-30-2017, 03:34 PM   #7
QC TORPEDO's Avatar
Pix
Here are 4 pictures.
1.An original vent in the ceiling
2.Removed
3.Curb side installed
4.Driver side installed
I apologize for the angles, I thought I had fixed them.
ID:	286549   Click image for larger version
ID:	286551   Click image for larger version
Old 05-31-2017, 10:56 PM   #8
Granbury , Texas
2.Removed
Looks great QC...don't think those will fall out! My wife want's to keep the original adjustable factory ones. I'll just have to come up with something like you if they start falling. This coming hot weather and a couple planned trips this summer should tell the story if I will need to modify...so far so good!
Old 09-14-2018, 04:18 AM   #9
Kensington , Maryland
QCT > Great work. I'll do similar however am thinking I'll stack two strainers together and cut/bend a small tab so that I can rotate the lower (stacked) strainer in order to adjust airflow. Thanks for the creative work.
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 10-08-2020, 09:13 AM   #10
2017 20' Flying Cloud
Williamson County , Texas
Been reviewing the posts on this topic when I discovered that removing a vent drastically increases how quickly we cool down the interior. It would be great if someone with HVAC experience could do some flow and pressure measurements to actually characterize the design issues.
2018 GMC Canyon V6 Mallet Supercharger
SYC2Vette is offline   Reply With Quote
Old 01-26-2021, 12:37 PM   #11
Del Mar , California
How do you remove the vents? Do they just pull out or are there some type of clips holding them in place?
BruBen is offline   Reply With Quote
Old 01-27-2021, 09:07 AM   #12
QC TORPEDO's Avatar
Removing a vent
They just pull out. Get a finger or a plastic or wood wedge started under one edge. Work around until it pops out. There are plastic clips attached to the vent.
Now that it is out, you can make the openings in the plastic ring bigger and use a needle nose pliers to make the louvers more open.
I have done both my original fix and made the vent opening bigger. Both work really well.
Old 03-06-2021, 01:09 PM   #13
2018 25' International
Decatur , Georgia
a slightly different approach
We had the same issues. The register in the bathroom kept falling out when in transit so we just took it down. Then we noticed the improved airflow. This last weekend, I removed all 6 registers. I drilled out the backside of the rivet and removed all the plastic diffuser parts and the rivet. Using a 6.5 inch piece of quarter round (I bought the plastic kind), I drilled a hole in the center then mounted it in the vent opening with some double sided tape to keep it in place. Using a 1.5 inch stainless screw, I just attached the vent cover to the quarter round. The vents will definitely not fall out anymore and you can still rotate the register to control the direction. It looks the same and we didn’t have to buy any new covers. We expect much better cooling and heating airflow and will test it out on our next trip.
Name:	vent cover.jpg
ID:	390041   Click image for larger version
ID:	390043   Click image for larger version
Plunderdog is offline   Reply With Quote
Old 03-06-2021, 07:27 PM   #14
2016 23' International
Thousand Oaks , California
The oem diffusers are terrible.. We made some adapter collars for spot diffusers a few years ago and now the ac actually works.
Unfortunately, they no longer make this spot diffuser... But anything that opens the restrictions up will make a dramatic difference in cooling. I can’t believe JC is still shipping new trailers with these terrible diffusers in them.
ID:	390075   Click image for larger version
ID:	390077   Click image for larger version
Seanlb is offline   Reply With Quote
plastic ceiling panels art Upholstery, Blinds, Walls & Interior Finishes 10 01-12-2008 12:18 PM
how to remove ceiling lights NewStreamer General Interior Topics 18 02-01-2003 04:41 PM
new furance or ceiling airconditioner with heat? striker Mechanics Corner - Engines, Transmission & More... 5 01-26-2003 10:03 AM
ceiling fan Cat Roof Vents, Skylights & Fans 0 10-06-2002 03:34 AM
