Caution regarding connection to Dometic Thermostat
First off I will say if you are not having a problem then probably don't mess with it.
That said i will leave it up to you whether or not to inspect this as an off season preventative maintenance task.
My thermostat went out mid trip and as I removed it from the wall, to check it, the connector pulled the receptacle completely off of the circuit card.
I was able to carefully resolder the 4 connections, but the very small tabs that held the receptacle to the board would only align it, not hold it in place so I added epoxy at 3 locations to hold it in place.
The problem was the cable was under tension and had zero slack in it so it had pulled on the connector. I was able to gain a small amount of slack to reconnect it, and everything worked after re-installing it.
Now back home I plan to open up the access hole, add an extension to the cable and then restrain it near the thermostat, with some slack in the cable so it will not be stressed in the future.
I will add some photos in a follow up post which will help explain this.
2018 GMC Canyon CCSB V6 Mallet Supercharger
2006 Chevrolet CCSB 2500HD 6.6T LBZ Duramax
