Originally Posted by frscott
...How do you track down a CO2 leak if that is what it is??
seems u mean CO (carbon monoxide) not C02 which is carbon Dioxide...
both are lethal is concentration, but the CO2 is an expired gas from animals and has too reach MUCH higher levels...
and there isn't a readily available CO2 detector, unless you are gonna buy a used space shuttle.
______________
first assume it is NOT a false alarm or faulty detector,
but you really should CHECK the device for reliability.
next what are the potential sources for co in the trailer air?
-the cook stove
-the oven
-hydrocarbon burning space heaters
-the furnace
-the water heater
-the refrigerator
-the tow vehicle
-cigarettes (the primary cause of co levels in human blood)
-candles and oil burning lamps
-wood/pellet stoves...
-that campfire on the lounge floor?
and so on.
_________________
IF the only thing running OR burning fuel is the furnace, start there.
i m no hvac guy but with a 20+ year old central furnace...
-it should be CLEANED and free of obstructions (mice/nests/webs/paper n stuff)
-it is supposed to EXHAUST out of doors, so go open the outside cover and look
---AFTER turning it OFF and TURNING OFF the gas supply, and perhaps disconnecting the juice (12vdc and 120AC)
-look 4 the stuff blocking the exhaust and for gaps in the sealant or trim pieces
-now go INSIDE and remove the cover, again looking for stuff and gaps.
beyond THAT a qualified RV hvac tech needs to inspect it.
imo the MOST likely, major issue is failure in the heat exchanger/manifold thingy...
old ones CRACK and leak co, this is NOT a good thing.
_____________________
any of the hydrocarbon burning STUFF can be an issue and each item needs 2b checked for venting, proper combustion and so on....
are u sure it's a CO detector and not a LPGAS detector?
does the detector take batteries or is it wired to the
12v system?
be safe, be sure, read the manuals and get a pro 2 check it out.
cheers
2air'
