Blizzard Heat Pump Install Question
Hi, I am installing a Dometic Blizzard Heat Pump on my AS. I have installed the Airstream drip cups on the unit and I see that it calls to use a second layer of gaskets so that I don't crush the drip cups when tightening the unit down.
I can't seem to find the part numbers for all of the gaskets. I found Dometic #3316315.013 which is the main gasket in the center of the unit but I can't find the smaller spacer blocks that are on the outside edges of the blizzard.
Has anyone completed an install of a blizzard that might know the spacer block part numbers or what they did in this situation?
BTW: I did call Dometic and they weren't sure and suggested calling AS. That's next if I can't find out from my favorite AS source.
Thanks! -Alden
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
