I had birds in my front AC only. Winterized, checked on it over the winter, then de-winterized in the spring. Found a lot of bird poop all over the roof and around that AC. Got a communication error from the thermostat and went up to investigate; opened the cover and found remnants of a nest. Got to the dealer and they were able to get the thermostat working again and noted the nest as well and cleaned out what I missed and noted there was no damage except for some styrofoam chewed away. Finished de-winterizing, went on a trip, placed in storage... a day or so later I checked on it and the birds were back in only the front AC again.
IN my research, Dometic knows that birds are entering on the street side of their units but have no current fix. Warranty says you cannot alter the unit... but warranty also doesn't cover damage from birds... so I went ahead and placed chicken wire on the inside of that area to both units and zip tied it.
No issues since.
As for the communication error... turned out to be an entirely different issue.
Jeff
2023 Flying Cloud FB Bunk
2024 GMC 2500 Duramax
