Old 12-12-2021, 10:53 AM   #1
2019 25' Flying Cloud
Pala , California
Atwood Sail Switch Part # ?
Hi,
I have a 2019 Flying Cloud with the Atwood AFMD25 furnace.
It failed to light this morning; fan starts and no ignition.
I can't figure out the part number as nothing matches the original attached below...
Any clues or replacement part numbers? None of the numbers on the switch match any internet searches. I'm off to a parts store now and hope to find but if not I'll have to order and want to get it right first time!
BTW it was pretty clogged with fur from my dog. Ya think it may be ok? I'm not gonna reuse unless I can't find and replacement so don't want to rebuild the furnace to check just yet!
Thanks!
TravisH is offline   Reply With Quote
Old 12-12-2021, 10:57 AM   #2
Pala , California
Oh I just found this one!
Ya think it's it? Same bracket and shape!
https://www.ebay.com/itm/12502635288...AaAn_QEALw_wcB
Old 12-12-2021, 11:03 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
TravisH,
Take a look here https://myrvworks.com/wp-content/upl...all-Manual.pdf and see if you can find or verify the part number for your model
Gary
GCinSC2 is online now   Reply With Quote
Old 12-12-2021, 12:51 PM   #4
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
TravisH,
If you cleaned the dog fur out chances are it will work. The easiest way to verify it's operation is with a multi-meter using the ohm or continuity function. If you don't have a multimeter when you move the sail you should hear a light click from the switch. Chances are it was clogged and not able to close the internal switch, I'd at least put it back together and try it while you wait for a new one.
88Limited is offline   Reply With Quote
Old 12-12-2021, 12:53 PM   #5
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
Also, check the serial number on your furnace... https://rvpartsexpress.com/product/d...-with-bracket/
Old 12-12-2021, 03:15 PM   #6
Pala , California
Thanks everyone!
I found one on the shelf at a local RV supply. Part number 33082 is what seems to be an exact replacement. They printed the numbers which don't seem to matter, in very dark grey on black so just did a visual match and trusted the computer at the store.
Fired right up!
I have a Dinosaur Board as well but have learned if it aint broke don't fix it so will leave stock panel unless anyone can convince me to change out now. I'd only save 5 minutes so....
Thanks!
Trav!
Fur In The Sail Switch! Rounder44 Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-04-2020 11:40 AM
Sail switch and dog hair Rak187 Furnaces, Heaters, Fireplaces & Air Conditioning 16 01-30-2020 04:01 PM
Beachstream -- Top Sail, FL Air Cruiser Forum Rallies & Meet Ups 2 08-01-2012 08:44 AM
Top Sail SP, Florida - Not the Canopener Air Cruiser On The Road... 8 12-12-2010 11:55 PM
Top Sail Hill Rv resort 73ANDY On The Road... 4 03-02-2003 12:17 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
