Old 10-14-2018, 02:16 PM   #1
2016 28' International
Sioux Falls , SD
Atwood furnace ignition lock out 2016 28’
I mistakenly posted this in water heaters, sorry.
Anyway, I had our furnace in our 2016 28’ go out in the AM after working the eve before.
We had a VERY bumpy road and heavy rain.
The furnace fan would come on and the furnace would light for about 4 seconds and stop. This happened 3x before completely shutting down.
The circuit board LED would flash 3x followed by 3 sec pause, indicating an “ignition lock out”.
Researching the forum brought a plethora of possibilities. Mostly a board failure kept showing up.
The board showed signs of water corrosion on it for which I will now caulk the door.
I have also coated ALL connections with dielectric grease.
I purchased a new Dinosaur replacement and it fired off immediately!
I have included old board and new board pics.
Hope it helps anyone else.
DanClick image for larger version
ID:	325189Click image for larger version
ID:	325190Click image for larger version
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 11-16-2018, 06:02 PM   #2
2009 30' Classic
a city in west GA , Georgia
May I ask where you purchased your board at?
Thanks ..... My light is flashing. X3 red also and all other possibilities ruled out. Thank you
Joyman is offline   Reply With Quote
Old 11-16-2018, 06:10 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I bought one from a seller on Amazon but shipped by Amazon. It didn't work. I called Dinosaur and they talked me through diagnosis. When they asked for the serial number to send me a replacement, they had sold it nearly a year before. They honored the warranty anyway and reset my warranty to my purchase date.
Save yourself some trouble. Google Dinosaur Board and buy direct.
Al
Old 11-22-2018, 12:58 PM   #4
Sioux Falls , SD
Buy direct from dinosaur.
2016 28’ HWT Atwood ignition lockout fault DBinSD Water Heaters, Filters & Pumps 3 10-11-2018 10:58 AM
Atwood RV 3 Burner Range and Oven w/ Piezo Ignition bowmansco Airstream Classifieds 0 08-07-2017 08:33 PM
Atwood water heater electronic ignition problem Deairstream Plumbing - Systems & Fixtures 0 07-09-2014 04:32 AM
Erratic furnace ignition beerrun'r Furnaces, Heaters, Fireplaces & Air Conditioning 11 10-23-2008 05:09 AM
Furnace Ignition Problem billberk Furnaces, Heaters, Fireplaces & Air Conditioning 25 01-12-2008 08:13 PM
