Atwood fires once, twice, then done.
2020 Globetrotter with an ongoing issue. When the thermostat calls for heat, the fan kicks on, the unit fires and all is good coming up to temp. Unit shuts off at temp. Generally, the second cycle is also successful. However, third cycle rarely fires. Fan runs for a bit and then unit shuts off due to lack of flame. Sail switch is clean, burner assembly is clean and igniters and sensor are gapped correctly. LP seems fine, all other appliances work. Hard to sleep when you are anxious waiting for the unit to shut off, plunging the interior temp into the low 50s. What else is there to troubleshoot? Any help is appreciated.
