Originally Posted by Dave18134
are there any drawbacks/advantages I have not thought of? Thanks!
You still CAN use 30 amp service, just shut one A/C off. I went back and forth also. I finally decided that living in Florida, I'd rather have the second unit even if I don't use it all the time than not have it and wish I did.
To me the biggest negative of the 50 amp service is giving up the brilliant front mounted 30 amp receptacle designed for easy access to a generator.
However, keep in mind the change from 30 amp to 50 amp is not just 20 amps. 30 amp service is one 30 amp 125v. service or 3750 watts. 50 amp service is two 50 amp 125v legs or 12,500 watts!
BTW, if you learn to "over/under" your 50 amp cable it's much more manageable. In my former MH, I coiled it right into the bay. No lifting, no tangles. However, with the AS and the generator I've purchased the same blue cable mentioned above. (Post #16) It can run to the generator or a 30 amp power post.
