Old 05-23-2023, 06:00 PM   #1
2008 27' Safari FB SE
2023 28' Pottery Barn
Delta , BC
Air Conditioning/Heat Pump
Does anyone know what units they are installing on new trailers today. One of my units doesn't work. Thought I would trouble shoot but I don't know for sure what I have, how to properly use, and no documentation. All I know is the controls on the czone system. There was a single sheet of paper in my owners manual that talks about the dometic warranty which I thought was what I had.
bugman3 is offline   Reply With Quote
Old 05-23-2023, 08:05 PM   #2
Cave Creek , Arizona
When I took the factory tour in March they mentioned they are currently installing four different A/C units depending on the trailer model. Our tour guide added that engineering was evaluating other AC units also trying to select “a couple” of long term suppliers. It sounded like the Coleman units are already down-selected.
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
Heat Pump/Air Condition Blowing Hot Air Safari-Rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-24-2012 08:30 PM
New Air-conditioning & Heat pump not working jagzoo Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-29-2010 07:57 PM
