Old 06-01-2023, 08:07 PM   #1
2017 25' Flying Cloud
Lakewood , Illinois
Air Conditioner Repacement on a 2017 FC
I have a 2017 FC FB 25' bought new. I'm fairly sure the AC never has worked since the day a bought it. We never travel south and never had much need for it, but every time I did try to use it it never seemed to do anything. When tested there was only a 4 degree difference from the air being dispersed. So I've decided to replace it. I'm going to attempt a DIY swap and planning on using the same unit (reluctantly I might add) for ease of install. First question I'm not sure of the BTU on the installed unit but will replace it with a 15K unit with heat pump. I don't think I need zones but my Dometic thermostat has them pre programmed. Any thoughts on a different AC unit I should consider and any DIY pitfalls I might encounter. Thanks
nedmoto is offline   Reply With Quote
Air Conditioner Repacement on a 2017 FC nedmoto Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-01-2023 08:06 PM
Question on dolmetic A/C return and air conditioner cold air mixing Joyman Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-07-2021 06:13 PM
'65 Caravel window repacement trout-fly Windows & Screens 3 11-28-2009 10:00 AM
Shower faucet repacement gergstuff All Argosy Trailers 4 08-02-2006 11:41 AM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
