Old 02-10-2024, 04:57 PM   #1
Newtown , Connecticut
Air conditioner Leaking water inside
Does anyone have an idea why the air conditioner would be dripping inside of the trailer
domblklab is offline   Reply With Quote
Old 02-10-2024, 05:59 PM   #2
Boxite's Avatar
2008 22' Safari
Two possibilities immediately come to mind:
1-The condensation drain-line is plugged (with algea or mud dauber/insect nest) or kinked.
2-The gasket which is supposed to seal the AC to the roof is not properly placed and is allowing condensation to form and drip inside.
Iíve seen both of these scenarios, with No. 2 being an outrageous amount of water if itís a humid environment or near the coast.
Old 02-10-2024, 08:44 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, it would help if you told us more about your trailer. Mine is a 2005 model with a one piece plastic A/C drain. They will eventually crack and leak. Later models have a two piece A/C drain which is an upgrade.
If like mine, with a little bit of work, you can seal the cracks. Or with a lot of work [remove air conditioner] to install the upgraded two piece drain kit.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 02-11-2024, 05:18 AM   #4
Thanks for the information, my trailer is a 2002 classic, I will check out the drain and the seals, hopefully I will be able to fix the issue.
Old 02-11-2024, 05:21 AM   #5
SlowPokePete's Avatar
2020 25' Globetrotter
Hillsdale , New York
I've cleared the drain line for the sunroof on my car by inserting a length of line from a string trimmer / weed wacker. Just rigid enough to punch through there.
Might work on your trailer's A/C drain.
SPP
SlowPokePete is offline   Reply With Quote
Old 02-11-2024, 08:05 AM   #6
2017 19' International
Tallahassee , Florida
Mine dripped water in the cabin when the air-return filters were dirty.
Cleaned the filters (easy to do), and no more drip.
I don't really understand this (I got the tip from another Airforums post), but it worked for me.
WhereStream is offline   Reply With Quote
Old 02-11-2024, 08:49 AM   #7
aftermath's Avatar
Spokane , Washington
Mine proved to be a crack in the condensation pan. It was a quick fix. I have a 2006 25FB
aftermath is offline   Reply With Quote
Old 02-25-2024, 09:17 AM   #8
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Check for a cracked or hole in your air-conditioned cover. I had a cluster of pecans fall from a tree in a campground and it punched a hole in my brittle AC cover. I kept wondering why the inside of the AC and carpet was wet after raining. Worse, it was working inside the panels and rotted the floor by the door. I didn't notice the 6" hole in the cover until I got on top of the trailer to check Fantastic Vent covers. Replaced the AC cover, repaired the floor and that cured the problem.
Old 02-26-2024, 05:49 AM   #9
gator.bigfoot's Avatar
KW , Ontario
lot's of discussion on this topic. Search AC drain or look here https://www.airforums.com/forums/f42...be-182389.html
gator.bigfoot is offline   Reply With Quote
Air Conditioner Leaking? alphamale49 Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-12-2018 07:55 PM
Air Conditioner Condensate Draining Inside Camper bigbuck1962 Furnaces, Heaters, Fireplaces & Air Conditioning 9 11-14-2016 10:26 PM
Air Conditioner Condensate Leaking Inside teamhaney General Repair Forum 16 08-18-2015 03:29 PM
Leaking Air Conditioner. Mick33 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-18-2014 05:51 AM
Rain leaking from Air Conditioner HCR Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-25-2012 05:30 PM
