Old 06-07-2024, 08:12 PM   #1
2023 20' Basecamp
Jefferson City , Missouri
Air Condition compressor does not start
We were camping last weekend and had a problem with our air-conditioning. We turned on the air to low, cool, but the compressor did not start. We let it run for a couple hours and the compressor had never started. Check the drain line, no water coming out the drain line.
Try a couple of times, through the breaker to see if that would help, but still no compressor, fan worked fine.
Next morning, I tried it again and the compressor came on first time.
Temperature was about 80° but humidity was about 85%. Thinking the compressor possibly froze up.
Anybody else have this problem or have any ideas? What may have caused it?
Midmomac is offline   Reply With Quote
Old 06-07-2024, 09:29 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
There are several possibilities; low on Freon is one. If your unit is a 2023, it should still be covered by Airstream. I’d start with the dealer or make an appointment with JC. Either way, it should be under warranty.
Good luck!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 06-07-2024, 10:37 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Bad start capacitor is a possibility
CRH is offline   Reply With Quote
Old 06-08-2024, 08:09 AM   #4
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
Try running it with the fan in auto.
There are several YouTube videos on how to check RV AC. This one was pretty helpful. It helped me rule out the compressor and thermistor. There are many other videos that could be helpful.
Yours is under warranty so I would probably take it back to the dealer before removing the lid, insulation, and shroud. Really don't want to void the warranty.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 06-09-2024, 07:44 PM   #5
2022 20' Basecamp
Stafford , Virginia
We've had ours freeze up, but it was only after trying to cool it rapidly when it was very hot and humid.
WeileMom is offline   Reply With Quote
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 14 01-20-2023 05:44 PM
delay air condition start on generator mcintoshMD Sprinter and B-van Forum 8 08-13-2019 06:29 PM
AC compressor will not start Jim Flower Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-01-2016 01:38 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 08:47 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 05:37 PM
