Originally Posted by 2012FB
I have read if you install an Easystart in both AC units you can run both off 30A. I ordered dual AC in our new 25 and plan on doing this. I am hoping that it does indeed work. We often camp where only 30 is available. Might be worth investigating further. From Easystart FAQ:
A:
Yes, installing an EasyStart on your two 15kBTU air conditioners should allow you to reduce the size of your generator and you would even be able to operate both 15kBTU A/Cs on a 30A utility hookup.
Granted, the total wattage required by twin 15kBTU systems would not leave much headroom for other appliances on a 30A cord, but being able to carry out such operation demonstrates the powerful capabilities of the EasyStart.
https://www.microair.net/pages/general-easystart-faqs
You need a good quality 30 amp connection to run two ACs and might need to shut off all other breakers. If the voltage is less then 115 volts before you start the first AC you shouldn't try to run the second AC. Lower voltage requires more amps and voltage often drops with more load, if the voltage drops too much it will damage your ACs. Also setting the fans to low speed will help a lot, lowering demand by 1 amp or more on each AC.
