Old 07-06-2018, 07:29 PM   #1
1976 31' Sovereign
RICHLAND HILLS , Texas
Adding 2nd A/C?
Hey, just joined. Im starting a full renovation of a 1976 31 Sov Mid Bath and am planning to make the rear section a bunk room for our kids with a door on it. I am debating adding a 2nd a/c in the rear and upgrading the electrical to 50 amp. I am pulling interior skins and re doing the entire wiring anyway but curious if anyone had any input if that was overkill/needed? We live in Texas so theres that. Second idea was running ducting thru cabinets into the room but I'm concerned it would just lower the efficiency of the a/c. Thanks!
IanSeekFirst is offline   Reply With Quote
Old 07-06-2018, 07:50 PM   #2
Hiwheel Joe's Avatar
1984 27' Sovereign
Central , Oklahoma
2nd AC
Texas+31 ft = 2 ACís. Havenít done it, but yes I wish I could. 50 is a must with 2.
Hiwheel Joe is offline   Reply With Quote
Old 07-06-2018, 09:24 PM   #3
2018 28' International
Fayetteville , Georgia
You will need dual A/C in Texas...
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 07-06-2018, 10:01 PM   #4
2016 26' Flying Cloud
Southlake , Texas
We just came home from CO with only 1 a/c working and it was hot until 10PM. After towing when itís over 100, it takes a long time for 1 unit to cool things down.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 07-07-2018, 10:03 AM   #5
Just got home from a week in Pigeon Forge TN. Temps were in the mid to high 90’s all week. 50amp/dual air kept us nice and cool at 72F. There is no way a 30amp/ single air would have kept up...
brick
brick
Cute wife...
Old 07-07-2018, 05:08 PM   #6
1976 31' Sovereign
Ok, appreciate the input! Then 2 it is! I was thinking that but without having experience with Airstreams, I wanted opinions and people who know! (proceeds to add a few thousand to the budget)
Old 07-17-2018, 10:44 PM   #7
ITSNO60's Avatar
Tucson , AZ
Anyone seen these? https://www.airxcel.com/coleman-mach...ile/mach-3-p-s
13,500 btu at 10 amps on "normal". You could probably get away with running 2 on a 30 if you managed startups. Or even 1 of these and a standard 13,500.
edit: looking at the specs it is misleading, shows RLA plus 4 amps at 115 ambient which if RLA on high is 1,440 watts like the chart shows add 4 amps to that and it is 15.2 amps but it also states FLA of only 11.2 amps... even 1,440 divided by 115 is 12.5 amps
Brian
ITSNO60 is offline   Reply With Quote
Adding a exterior 2nd battery-72 GT manook Electrical - Systems, Generators, Batteries & Solar 2 08-25-2011 06:45 PM
'99 Safari, Adding 2nd Battery on Tongue Soyboy Batteries, Univolts, Converters & Inverters 5 04-23-2010 10:31 AM
Adding 2nd AC Unit in the bedroom? TxToaster Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-12-2009 07:31 PM
Adding 2nd Battery--Any problems? Pete Vermont Batteries, Univolts, Converters & Inverters 8 01-24-2008 04:20 AM
Adding 2nd battery to 16 CCD? smccollister 1997 - 2004 Bambi 33 01-21-2007 08:33 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
