Old 09-27-2023, 10:42 AM   #1
2003 25' Safari
weyers cave , Virginia
AC unit has small leak when it rains
Hello everyone. I have a 2003 25-foot Safari, which has served us very well. There are a few leaks here and there, but all were correctable. More recently, I have noticed water slowly dripping in the interior ceiling from the front of the Dometic Duo-Therm Penguin AC unit. The unit still works well. The condensation drip tube is working as evidenced by a steady flow of water when the unit is in AC mode.
When I remove the two filters, I can see the two forward bolts holding the AC unit onto the ceiling. But I can't see the two posterior bolts. I want to tighten them all to see if that helps the leak.
What do I need to do to get to the other two bolts? If there are even two posterior bolts?
This only happens when it rains. I have yet to get on top of the trailer to see if the shroud is cracked. I replaced it about 8 years ago, as cracks developed where the holding screws held the shroud to the outside unit.
thanks for any help in the next steps of diagnosis and treatment.
Name:	Holding bolt forward 1.jpg
ID:	437316   Click image for larger version
Name:	Holding Bolt forward 2.jpg
barticus is offline   Reply With Quote
Old 09-28-2023, 06:30 PM   #2
2003 25' Safari
Looking at the covering on the roof, no cracks, and it looks good. I took off the interior shroud. There were only three long screws. Two in the front and one, midline, in the back. No other holes to indicate a forgotten screw. No pieces of foil cover any open holes. My guess is that this particular Dometic model had only three screws.
They were all fairly loose, so i tightened them. Not quite to the 40-50lbs torque indicated in the manual. I will watch for further leaks and tighten as needed.
Old 09-28-2023, 06:52 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
PM sent
CRH is offline   Reply With Quote
Kitchen hood vent leaks when it rains rogerdodger Roof Vents, Skylights & Fans 1 05-31-2020 12:25 PM
A/C Leaks When It Rains, Does Not Leak Condensation Steve Bryant Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-16-2013 08:24 PM
The first big rains. joelreh Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 10-25-2010 12:50 PM
Kitchen hood vent leaks when it rains rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 05-20-2010 09:38 AM
1982 280 Leaks when it Rains k_rasmussen Classic Motorhomes 10 11-24-2006 08:04 PM
