Old 06-02-2024, 01:54 PM   #1
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
AC Trouble Shooting Part 2 The Block of Ice
During our last trip we were having issues with the air conditioner turning into a block of ice after running about 30 minutes. Hmmm.
First attempt: Shut the AC off and clean the compartment suction filters. Restart and 30 minutes later the same thing happens.
Second attempt:
1. Climb up on the roof and remove the AC cover.
https://www.airforums.com/forums/att...1&d=1717356806
2. Remove the Fan/Coil shroud insulation.
https://www.airforums.com/forums/att...1&d=1717356955
3. Remove the fan/coil plastic shroud. Now I am looking at the fan and AC coils.
https://www.airforums.com/forums/att...1&d=1717357029
On the opposite end of this are the heat pump coils.
I get my coil cleaner, water spray bottle, towels and clean all the coils (heat pump too). This had not been performed since my rig was purchased. During the cleaning I also note that there does not appear to be a freon leak and the compressor starts when the AC is started. About 2 hours later, everything is back together and the tools are put away. I'm feeling pretty good about where this is going.
Turn the AC back on and 35 minutes later I get the same block of ice. I am starting to doubt my mechanical abilities.
https://www.airforums.com/forums/att...1&d=1717357461
I take another picture and stare at it for a few minutes.... What is that thing hanging there by the coils?
https://www.airforums.com/forums/att...1&d=1717357519
Ahhh the thermistor sensor has fallen out of the coils. Why did I not just look up here first? FYI, the thermistor controls the compressor to prevent a block of ice from forming. I had forgotten K.I.S.S. (Keep It Simple Stupid).
Just thought this might be helpful in case any of your were having the same issue.
Name:	Roof Top 1.jpg
ID:	443936   Click image for larger version
Name:	Roof Top 2.jpg
Name:	Roof Top 3.jpg
ID:	443938   Click image for larger version
Name:	Block of Ice 1.jpg
Name:	Block of Ice 2.jpg
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 06-02-2024, 08:43 PM   #2
1988 32' Excella
Robbinsville , New Jersey
Running the fan on high also helps reduce problems with ice.
Solar Panel Trouble Shooting Help upstateart Winter Living 8 01-31-2010 07:13 PM
Trouble shooting 120V breaker box stanwilder Batteries, Univolts, Converters & Inverters 10 06-19-2009 02:08 AM
Trouble shooting 64 magic chef stove 59er Stoves, Ovens & Microwaves 4 08-28-2007 10:40 AM
Yamaha 2400is trouble shooting Boondocker Generators & Solar Power 29 06-17-2007 04:06 PM
Trouble shooting Furnace/Heat Pump/Air C? Kistler Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-07-2007 12:13 AM
