Old 05-23-2020, 01:55 PM   #1
1972 23' Safari
Middletown , Rhode Island
AC Thermostat control question
So I'm planning on switching out my old 1972 armstrong ac to the Dometic Low Profile Penguin 2, the Armstrong used a wall mounted thermostat to turn it on and off, can I use the same thermostat or replace with a modern one to control my new ac and bypass the controls on the actual unit. The new ac also has the heat strip. Thanks. Dan
Mx468 is online now   Reply With Quote
Old 05-23-2020, 03:14 PM   #2
2018 25' International
Slidell , Louisiana
The Dometic website has the installation manuals you can download. the manual describes how to wire a traditional 5 wire thermostat or if you can fish some phone cord through, you can upgrade to the CCC2 controller. The manual details what features you can use with either approach.
Brian
Old 05-23-2020, 03:30 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
you can use any home type controller .
some even use a nest and ecobee type
waninae39 is offline   Reply With Quote
retrofitting a manual control non-ducted to a Cycled Digital Thermostat rodsterinfl Furnaces, Heaters, Fireplaces & Air Conditioning 16 08-02-2017 07:22 PM
Climate control thermostat in Flying Cloud 27' Peny 2016 - Current Flying Cloud 7 10-23-2016 05:10 PM
Dometic Comfort Control Center 2 Thermostat dave_oleary Electrical - Systems, Generators, Batteries & Solar 13 09-27-2014 05:32 AM
