Old 05-20-2021, 03:25 PM   #1
zephyr9900's Avatar
1972 27' Overlander
GERMANTOWN , WI
AC retrofit on 72 Overlander works better with a flat ceiling
I purchased the 72 Overlander in 2012 and immediately installed a new Dometic Penguin Air Conditioner similar to a video I found by Classic Rides. But the problem I have is that the ceiling is not flat in an Airstream but the Dometic AC unit is made for a flat ceiling. This causes the control knobs to not engage correctly and sometimes they fall out or not work.
To solve the problem I made a flat ceiling adapter.
Before installing the adapter the AC mounting frame around the opening was fabricated to match the ceiling shown in the attached PDF "AC Roof Mount Frame"
Next I made a ceiling adapter that transitions the curve ceiling to a flat ceiling. The most difficult part to make are the cured trusses made from 1 X 2 pine boards.
The flat area of the adapter is made from 1/4" hardboard.
I have my own machine shop so made the trusses and mounting frame curved parts on a CNC milling machine. These can be made pretty fast once the machine is setup. (If you think I might be able to help you please contact me.)
Attached are some photos and a drawing of the curved truss.
John
ID:	395839   Click image for larger version
zephyr9900 is offline   Reply With Quote
Which would you rather? Better brakes, better hitch, or better wheels/tires? bjmckernan General Repair Forum 30 07-17-2016 07:47 AM
$5 Retrofit LEDs for 6-light ceiling lights in '73 Overlander aquinob Lights - Interior & Exterior 48 05-14-2015 01:36 PM
New flat screen TV needs better 12 volt speaker system, any ideas ? Trident Land Yacht/Legacy Motorhomes 16 08-27-2014 05:44 PM
LED Retrofit for Fluorescent Ceiling Vent/Light vswingfield Lights - Interior & Exterior 5 12-30-2012 08:36 PM
New stripper that works better bwaysteve Cleaning, Stripping & Polishing 2 02-27-2010 06:55 PM
