Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-26-2021, 07:42 AM   #1
nadrad314's Avatar
2021 27' International
Mount Zion , Illinois
AC reads exterior temp as interior?
Just got my new, right off the assembly line International FB27. The AC runs and runs and the only way I got it to turn itself off is to raise the thermostat to 79F. Which, happens to be the outside temp. The temp inside the trailer is a comfortable 71F. When I press the "Exterior Temp" button, it tells me it's 79F outside, which it is.
Anyone else experience this? Does anyone know where the sensor is for the INTERIOR temperature? The manual does not help much. It merely says the interior sensor is in Zone 1. I only have one zone, for I only have one AC unit.
Any thoughts would be appreciated!
Thanks!
Jon Nadler
Downstate Illinois
27' International FB
TV: F-250, 7.3L Gas Engine
nadrad314 is offline   Reply With Quote
Old 07-26-2021, 08:14 AM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Normally the sensors are located right over the TV set ....
Old 07-28-2021, 12:51 PM   #3
2015 28' Flying Cloud
Newtown , Pennsylvania
The sensor is probably lost in the wall. This happened to me. Better let Airstream fix it.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
400ah LiFePo4, 800 watts solar, 2x eu2000i Propane
PD9160 converter, Prosine 1800 inverter
2x Victron 100/30 Smart Solar, Victron Smart Shunt
AstroBruce is offline   Reply With Quote
Old 08-06-2021, 08:40 AM   #4
nadrad314's Avatar
Thanks for the comments! Do appreciate the insights!!
Airstream is going to look at it. Won't be until October because they're backed up, but that is okay. The air and heat works just fine, I just have to play around with the setting to get it comfortable.
Jon Nadler
Downstate Illinois
Vroom Vroom.. Non Airstream Reads... Kevin245 Off Topic Forum 2 06-04-2010 02:42 PM
Micro Pulse Monitor reads red when unhooked foqus Batteries, Univolts, Converters & Inverters 11 11-03-2009 09:34 PM
black water sensor reads 3/8th all the time javamaude Waste Systems, Tanks & Totes 18 10-09-2009 01:46 PM
Sink drain creates toilet bubbles, greywater always reads full dre00 Plumbing - Systems & Fixtures 22 02-02-2009 12:13 PM
