Old 07-18-2017, 09:21 AM   #1
2013 28' Flying Cloud
Lincolnton , North Carolina
AC Noise
Has anyone been able to muffle the ac noise. Can't even hear tv when it is running. Now we are having tv issues. Seems to be a short and cuts off. Happens often when ac vibration is bad.
sydspainhour is offline   Reply With Quote
Old 07-18-2017, 02:24 PM   #2
Rich W's Avatar
I'm In , Kentucky
That compressor is right overhead and the fan is just below it, middle of the AS. I doubt that you will be able to muffle it without affecting its performance. We keep the fan on "auto" so it's not always running. If it's not too hot, we just turn it off for a while and use a small fan move the air around. Other than that, we just turn up the TV or go outside and do something else.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 07-18-2017, 05:04 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
We occasionally get caught in a situation where we need the A/C but we try to avoid using it. It is loud, and there's no way around that.
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 4 08-07-2020 11:13 AM
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 12:18 PM
"Whirring" Noise in the Driveline at Speed swebster Airstream Motorhome Forums 20 08-15-2003 06:57 AM
Noise dry camping ChrisAich 2002 - 2005 International 24 07-28-2003 07:58 AM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 07:23 AM
