AC leak with clear drain line
I have water leaking from the seams inside my trailer. Not the ceiling, the wall seam in my kitchen area directly down line from the ac unit. The drain line is clear and draining. I removed the cover, the evaporative’s drain pan was clear, though there seamed to be excess water on top of the evaporative coil plastic cover (between the plastic cover and foam). We had heavy rain 15 hours prior to leak. The ceiling vent directly in-line with the leak has droplets of water on the vent. Inside humidity is 48-50. Four family members took showers a couple hours prior to noticing the drips. Thoughts?
- Stewart
