AC Heat Pump use same drain pan?
Sorry if this is a silly question.
When using my Dometic AC units as air conditioners to cool, I get condensate dripping normally through the two street-side drip hoses in the wheel well.
When I use the AC unit as a heat pump, no drip hose draining, but I get a steady stream of drips off the roof that finds its way to the door-side rear where the gutter rail ends, most probably the way the trailer is less than level.
Should the heat pump operation use the same AC drip hose?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
