Old 10-23-2018, 09:05 AM   #1
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
AC Heat Pump use same drain pan?
Sorry if this is a silly question.
When using my Dometic AC units as air conditioners to cool, I get condensate dripping normally through the two street-side drip hoses in the wheel well.
When I use the AC unit as a heat pump, no drip hose draining, but I get a steady stream of drips off the roof that finds its way to the door-side rear where the gutter rail ends, most probably the way the trailer is less than level.
Should the heat pump operation use the same AC drip hose?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 10-23-2018, 10:17 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have experienced the same "phenomena". We have always done a lot of Airstreaming camping in the cooler weather. We have noticed that condensation usually drips from one corner of the trailer.
I think what is happening is that condensation forms on the roof of the trailer outside of the pan. The aluminum roof surface is cool or cold and the heat pump is blowing out some warm air. When the condensation get to a sufficient volume, the water drips down to the low end of the Airstream. It could appear at any point on the trailer depending on how you are leveled up.
By the way, this is my totally unscientific assessment based solely upon long term observation.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 10-23-2018, 12:39 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Condensation occurs at different places when the unit is in different modes.
When the unit is in heat pump mode, occasionally it might run a defrost cycle to keep the outside part of the condenser free from ice buildup. When this happens the melted ice/condensate might run onto the roof.
This is just the opposite of when cooling mode is used, when ice/condensate builds up on the inside of the unit and drips out the drip tube.
Alan
Old 10-23-2018, 03:19 PM   #4
As they say, A-HA!
Thank you, Brian and Alan, for your wisdom and experience. Just love this board and all of you. The journey is safe and fun with you along for the ride.
WBCCI #6679
Old 10-24-2018, 01:50 PM   #5
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
2017 25a FC, and the exact same situation happens on the door side to... confirmation.
HHPJ is offline   Reply With Quote
Heat pump and furnace come at same time Wayne&Sam General Repair Forum 3 08-25-2018 11:26 AM
Same old, same old whitegs Tow Vehicles 36 08-11-2016 03:22 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
How is this possible, same manf, almost same frame, diff GVWR carl2591 Tow Vehicles 7 07-15-2014 07:23 PM
