Old 08-10-2024, 11:29 AM   #1
1968 17' Caravel
Clarkston , Georgia
AC drain issue
Howdy: I have a older rooftop Dometic AC unit on top of my 68 Caravel. When the AC is running water is dripping out of the belly pan. Did these older units have drain lines and if so where might I locate it?
M.Riley is offline   Reply With Quote
Old 08-10-2024, 12:14 PM   #2
1988 32' Excella
Robbinsville , New Jersey
It should have a drain line coming through the belly pan near (usually in front of) the street side tire, on some trailers it hung down a couple inches, on others it barely made it out of the belly pan and could slip inside.
Old 08-10-2024, 05:41 PM   #3
1968 17' Caravel
Clarkston , Georgia
Thumbs up AC Drain Issue
Wazbro thanks for the reply.
I found the drain line just a few minutes ago. The belly pan is saging a bit and the line isn't long enough to protrude from the hole in the pan. When I push up on the pan the line sticks out about 1/4". I just need to extend the line an inch or so; at least it isn't clogged.
Old 08-11-2024, 10:24 AM   #4
1988 32' Excella
You're welcome, from your description I thought you probably had one of the shorter hoses. Glad you found it.
2018 Fresh Water Drain Issue observer Sprinter and B-van Forum 19 08-08-2017 07:46 AM
Ac drain issue continued DJT13 General Repair Forum 8 11-13-2016 11:12 AM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
'77 Argosy drain issue bignip1989 Sinks, Showers & Toilets 2 01-08-2015 05:21 PM
Another drain issue azfiredog300 Fresh Water Systems 4 03-18-2013 08:31 AM
